Author Topic: Gov Mod Shim  (Read 3140 times)
November 28, 2013, 03:11:00 pm
shwak23
  • 417
    • Blackdog Junkyard
Gov Mod Shim
« on: November 28, 2013, 03:11:00 pm »
What do you guys use for shimming your gov solid?
I was thinking about using a piece of copper nickel brake line or fuel line cut to the same size as the spring.
Any other better suggestions?
Sent From Outer Space
Reply #1November 28, 2013, 04:26:54 pm
Re: Gov Mod Shim
« Reply #1 on: November 28, 2013, 04:26:54 pm »
I think most folks use a few hardware store washers.  I used a roller from a bike chain because I happened to have it and it fit.
Reply #2November 28, 2013, 06:24:11 pm
shwak23
  • 417
    • Blackdog Junkyard
Re: Re: Gov Mod Shim
« Reply #2 on: November 28, 2013, 06:24:11 pm »
Yea I know you can shim it with washers but how does one shim it solid?
Reply #3November 28, 2013, 06:24:48 pm
Re: Gov Mod Shim
« Reply #3 on: November 28, 2013, 06:24:48 pm »
I used #8 washers IIRC from my work.
If you want to shim it solid, use more washers
Reply #4November 29, 2013, 07:09:25 am
Re: Gov Mod Shim
« Reply #4 on: November 29, 2013, 07:09:25 am »
...plus you need to think about whether you actually DO want to shim it solid.  I wouldn't recommend it personally.  Even a very small shim makes a huge difference.  Unless you have plans to regularly run to 6500 RPM having a bit of spring left in the governor is a good thing.
Reply #5November 29, 2013, 08:51:03 am
Re: Gov Mod Shim
« Reply #5 on: November 29, 2013, 08:51:03 am »
...unless you want to bend/break your control lever assembly...
Reply #6November 29, 2013, 03:47:30 pm
dieseljunkie69
  • 47
    81 Jetta
Re: Gov Mod Shim
« Reply #6 on: November 29, 2013, 03:47:30 pm »
Yup. I've had this happen!
I'm That Guy.
Reply #7November 30, 2013, 02:02:45 pm
carrizog60
  • 978
Re: Gov Mod Shim
« Reply #7 on: November 30, 2013, 02:02:45 pm »
and its really hard to put it back toghether lol
Portugal
Reply #8February 08, 2014, 03:11:45 pm
dieseljunkie69
  • 47
    81 Jetta
Re: Gov Mod Shim
« Reply #8 on: February 08, 2014, 03:11:45 pm »
I usually use 3 or 4 of the delivery valve copper washers when I do reseals.
I'm That Guy.
