Author Topic: Who's built a powerhouse 1.6TD?  (Read 16206 times)
Reply #30July 26, 2013, 05:51:48 am
Gizmoman
  • 1301
Re: Who's built a powerhouse 1.6TD?
« Reply #30 on: July 26, 2013, 05:51:48 am »
I ran across this. . .
http://forums.tdiclub.com/showpost.php?p=3677136&postcount=3\
Basically says "100 HP is easy to make" - includes instructions ;)
Reply #31July 26, 2013, 06:35:59 am
« Reply #31 on: July 26, 2013, 06:35:59 am »
The 1V was the Eco and the worst engine to compare. I agree there is no replacement for displacement though.
If you want to build an engine and don't want to put a ton into it the 1.6 rods are probably the last thing I would ever replace. They are very robust, same with the crankshaft. On a 1.9 they are what I would replace first as they are not as thick as the 1.6 and they are longer, and the 1.9 has more force going to them.
To make a 1.6 a faster car you should look at all of the forum. It is quite easy, but we would really need to know your goals.
Reply #32July 26, 2013, 06:53:16 am
« Reply #32 on: July 26, 2013, 06:53:16 am »
Funny, because the 1.9s are close to 3
$3000 down here.. How much did you think I was going to spend on my lil 1.6?
Engines cost $250 more than the lowest sale price anywhere in the country.  Anyway, you're probably right.  Do it your way.  Good luck.
« Last Edit: July 26, 2013, 06:55:11 am by libbydiesel »
Reply #33July 26, 2013, 07:38:23 am
« Reply #33 on: July 26, 2013, 07:38:23 am »
i endorse this message
i think the 1.9 bottom end issue is due to the longer stroke and more power/smaller turbo.
Reply #34July 26, 2013, 02:53:21 pm
Alcaid
  • 549
« Reply #34 on: July 26, 2013, 02:53:21 pm »
We've dynoed 173whp on a bone stock 1V Ecodiesel bottom end and a stock AAZ head, easypeasy ;)
I have a 1.6td biturbo powerhouse in the making but don't recommend building anything similar to anyone, not cheap to say i mildly...
'10 VW Passat 1.6TDI Highline
Reply #35July 26, 2013, 08:52:58 pm
wut_cel
  • 34
« Reply #35 on: July 26, 2013, 08:52:58 pm »
So many posts to respond to.. I'll get to them later.
My goals are to build a beefy 1.6 that I daily.
Reply #36July 26, 2013, 10:05:44 pm
« Reply #36 on: July 26, 2013, 10:05:44 pm »
If u do a 1.6 up with a ported head and upgraded intake with a modern turbo and performance injection pump, u may see impressive results
Reply #37July 27, 2013, 01:08:16 pm
wut_cel
  • 34
« Reply #37 on: July 27, 2013, 01:08:16 pm »
That's what I'm thinking, I'm not trying to build a rocket, just something that is reliable and can move.
Reply #38July 27, 2013, 04:08:53 pm
« Reply #38 on: July 27, 2013, 04:08:53 pm »
Just bolt a performance pump on. Jessabug or rockerchick did that with their jetta and says it moves quite well.
Reply #39July 28, 2013, 10:48:44 am
dodger21
  • 97
Re: Re: Who's built a powerhouse 1.6TD?
« Reply #39 on: July 28, 2013, 10:48:44 am »
Anyone ever thought about an HE211 sucking from an eaton MP45?
I want this setup in a 85 MR2
1985 Golf 1.6NA with a 5spd
Reply #40July 28, 2013, 05:24:22 pm
« Reply #40 on: July 28, 2013, 05:24:22 pm »
On a diesel or original engine???  U could do a much larger turbo if ur using a supercharger too
Reply #41July 28, 2013, 05:49:18 pm
dodger21
  • 97
« Reply #41 on: July 28, 2013, 05:49:18 pm »
But anything bigger is way out of the 1.6Ls efficiency. Unless others have used an HX35. That would be the next step up from the HE2xx size.
Reply #42July 28, 2013, 07:00:28 pm
« Reply #42 on: July 28, 2013, 07:00:28 pm »
Yeah but if you have a supercharger the efficiency changes.  The next step would be more like an hx30.
Reply #43July 30, 2013, 03:23:03 pm
CrazyAndy
  • 739
« Reply #43 on: July 30, 2013, 03:23:03 pm »
HX35 series is WAAAAAY too big, even for a 1.9 diesel;  there just isn't enough flow to spool the huge turbine.  This of course is speaking of the turbo by itself, since I know of literally no one in the country who has made a super-turbodiesel.
Reply #44August 03, 2013, 01:19:32 pm
dodger21
  • 97
Re: Re: Re: Who's built a powerhouse 1.6TD?
« Reply #44 on: August 03, 2013, 01:19:32 pm »
Not a VW to my knowledge but a Cummins and Duramax have been.
