Author Topic: Yet another timing question, is my pump retarded?  (Read 7688 times)
Reply #15June 19, 2013, 08:34:25 pm
millertime
  • 38
Re: Yet another timing question, is my pump retarded?
« Reply #15 on: June 19, 2013, 08:34:25 pm »
I will try that, whers the idle screw? Thanks
Reply #16June 19, 2013, 09:52:25 pm
  • 4550
« Reply #16 on: June 19, 2013, 09:52:25 pm »
It is the one the throttle arm is resting on when at idle.  The second one back next to the engine.  10 mm nut to release, Screw driver to turn in and then Hold the position with the driver and tighten with the wrench.  Might only need a half to three quarters of a turn.
Reply #17June 20, 2013, 02:50:34 am
millertime
  • 38
« Reply #17 on: June 20, 2013, 02:50:34 am »
awesome thank you.
Reply #18June 20, 2013, 05:40:08 am
VTPSD
  • 107
« Reply #18 on: June 20, 2013, 05:40:08 am »
going to replace my lifters tonight, so i will have a chance to see if my pump is indeed off by a tooth. I still think it could use a bit more advance, starts without cold start handle now but barely rattles even when it was 40F this morning. Cant wait to get quiet lifters in this thing!
-1991 audi 90 quattro with AHU tdi, r520's holset he211
-1990 audi 90 quattro, holset turbo, 11 second quarter mile demon
Reply #19June 20, 2013, 07:14:13 pm
Re: Re: Yet another timing question, is my pump retarded?
« Reply #19 on: June 20, 2013, 07:14:13 pm »
The oil pressure alarm is connected to the switch on the oil filter flange, so low pressure at the head while having decent pressure right after the pump can easily cause problems like you describe without triggering the alarm.
Ever use RTV on this engine? Always possible there's a plugged supply passage somewhere.
Sent from my HTC One X using Tapatalk 2
