Author Topic: Oil return Line.  (Read 11657 times)
Reply #45June 19, 2013, 05:44:42 am
JerryGTD
  • 89
Re: Oil return Line.
« Reply #45 on: June 19, 2013, 05:44:42 am »
My MK1 CY TD setup that I used on my 85 Jetta.
1991 Jetta GL ECOdiesel
Reply #46June 19, 2013, 06:31:20 am
One_punchmachinegun
  • 261
Re: Re: Oil return Line.
« Reply #46 on: June 19, 2013, 06:31:20 am »
Hm, I tried that route without any luck. At the bottom the end of the return line it wouldnt go anywhere near the flange on the oil pan. What turbo is on that?
The only way the line got close to the flange was if I turned it around 180' but then it wouldn't clear at the top with the exhaust manifold.
Wonder if it has something to do with the position of the center part of your turbo. Clocking the turbo might have worked.
I think I'm going to go the other route, now that I have committed. I have the turbo and everything on, and torque to spec. So it will stay there until I get a rear mount that allows me to run it this way.
“If anyone hears my words but does not keep them, I do not judge that person. For I did not come to judge the world, but to save the world." Jesus Christ
Reply #47June 19, 2013, 07:42:07 am
JerryGTD
  • 89
« Reply #47 on: June 19, 2013, 07:42:07 am »
It's a stock 1.6 T3 from a 1983 Jetta.
Reply #48June 19, 2013, 08:00:50 am
One_punchmachinegun
  • 261
« Reply #48 on: June 19, 2013, 08:00:50 am »
Did you have to modify the line at all to clear the rear mount.
Sent from my HTC One X using Tapatalk 2
Reply #49June 23, 2013, 05:03:24 am
JerryGTD
  • 89
« Reply #49 on: June 23, 2013, 05:03:24 am »
No modifications were required. That is the factory designed return line and oil pan.
