Author Topic: TDI flywheel/VR6 clutch (228mm) - AAZ Vanagon  (Read 7595 times)
Reply #15June 17, 2013, 03:46:00 pm
CrazyAndy
  • 739
Re: TDI flywheel/VR6 clutch (228mm) - AAZ Vanagon
« Reply #15 on: June 17, 2013, 03:46:00 pm »
Just wondering, is that plate even needed?  Does it serve the function of a spacer?  Or is it just the case of 'It came with it, and darn it, I'm gonna re-use it!'?
Reply #16June 17, 2013, 05:26:52 pm
Gizmoman
  • 1301
« Reply #16 on: June 17, 2013, 05:26:52 pm »
No, I don't think it's absolutely needed but leaving it off would expose the flywheel a bit on both sides of the block. I don't plan on any diesel or oil leaks but who does. Besides, in any engine bay there must be some significant air swirling about (especially at 100 MPH ;D), and should a leak happen, slippery stuff might end up getting in there.
I figure Keeping the flywheel clean is a great way to keep the clutch from slipping.
One of the things I noticed though is the "0" timing mark on the (non-stock) flywheel is not in the correct place - not even close. I won't know the "correct" spot till I slip the tranny on and set it to TDC based on the arrow on the bell housing. I may buff out the current mark so there's no confusion.
