After pulling out all the parts from the block, I saw the rod bearings have this wear pattern. It looks like pre-detonation. Or is it oil starvation? I've seen oil starvation as grooves or pealing of the bearing surface.Again never seen this in any engine overhaul I've done. This is only after 600 miles of running.Any body seen this before?
That's just strange. You'd never guess looking at those you have so little miles on them. What did you put on the bearing upon assembly? I wonder if you had some strange oil on your hands that etched those bearings? Did you plasti-gauge them after install?
http://www.ngpracing.com/newstore/eurospec-sport-billet-main-bearing-caps-all-vw-audi-4-cylinder-5-piece-kit.htmlsolution^
