Author Topic: After 600 miles, I got 2 cracked main caps. What the heck.  (Read 26149 times)
Reply #60June 19, 2013, 04:43:03 pm
Re: After 600 miles, I got 2 cracked main caps. What the heck.
« Reply #60 on: June 19, 2013, 04:43:03 pm »
I'm pretty sure redline is 4500 for both engines.
If you only drive 65 then your gearing is probably acceptabe given the wright and coefficient of drag. Andrew would know better though.
Reply #61June 19, 2013, 10:02:04 pm
  • 4549
« Reply #61 on: June 19, 2013, 10:02:04 pm »
TonyTD.  on that site of the gears there is a link to Miata and they will show you the differences between wheel and tire combos.  Diameter, height etc.  Try looking around on that for giggles/
Reply #62June 20, 2013, 06:40:25 am
« Reply #62 on: June 20, 2013, 06:40:25 am »
Your gearing would be fine.  I didn't realize you were running tires that large.  IMO, no harm will come to a TDI from high revs.  You could cruise at 4,000+ all day long, but if you did, unfortunately your fuel economy would be in the toilet and the engine would run a lot hotter.  With your tires, tho, if my math is right you're still only turning 3555 at 75.  The engine would be more comfortable/efficient at 65 but IMO no damage will result from 75.
Reply #63June 20, 2013, 08:05:35 am
TonyTDTruck
  • 110
« Reply #63 on: June 20, 2013, 08:05:35 am »
I should have mentioned Im running a DoKa. This one is a Syncro 16. They come with longer trailing arms and larger wheel wells. These DoKas can fit 30.5" tires. Some day I might do that but it's good to know I don't have to worry too much about it.
I have pulled the engine and soon I will have main caps and a TDI crank to repair this AAZ. I will use ARP studs for the mains this time. This will be done at a machine shop.
I have ARPs studs for the head. Can I re-use these? I hope so because they are not cheap. But then again, neither is removing the head and a broken head bolt.
Thanks libbydisel.
Tony
How do you wash a pressure washer?
And did you know that the 14th floor in a
hotel is actually the 13th floor!
Reply #64June 20, 2013, 04:35:04 pm
Syncroincity
  • 727
« Reply #64 on: June 20, 2013, 04:35:04 pm »
Yes, the ARP head studs are unlimited-use. Be sure to use a moly lube similar to what they provided with them originally when installing to get accurate torque readings.
I had mine at 100 ft-lbs, and some have gone up to 125.
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
Reply #65June 21, 2013, 08:37:14 am
TonyTDTruck
  • 110
« Reply #65 on: June 21, 2013, 08:37:14 am »
Here are the studs for the mains. OUCH! these are expensive. A lot less than what I'm going through right now though.
I spoke with a machine shop and they told me I might be wasting my time with trying to line bore this block. They are saying that if the bore isn't straight the piston height will be affected. They couldn't guarantee it. Oh crap! Maybe I should get a second opinion. Or get a whole used block assembly. That could be cheaper. :'(
http://techtonicstuning.com/main/index.php?main_page=product_info&cPath=2_11_5_248&products_id=457
« Last Edit: June 21, 2013, 02:20:35 pm by TonyTDTruck »
Reply #66June 21, 2013, 01:28:34 pm
Jetmugg
  • 530
« Reply #66 on: June 21, 2013, 01:28:34 pm »
I got a mild chuckle from the machine shop comments (if it's not straight...).  After all, it is their job to make sure that the line boring is done parallel to the deck surface.
Steve.
Reply #67June 21, 2013, 01:30:04 pm
« Reply #67 on: June 21, 2013, 01:30:04 pm »
Tony, the link you posted is for head studs, not mains.
Reply #68June 21, 2013, 02:21:29 pm
TonyTDTruck
  • 110
« Reply #68 on: June 21, 2013, 02:21:29 pm »
oops I got it corrected. Thanks libbydiesel.
Reply #69June 21, 2013, 03:10:28 pm
« Reply #69 on: June 21, 2013, 03:10:28 pm »
If you use the arp part # and go to summit racing they are usually cheaper
Reply #70June 21, 2013, 05:19:18 pm
« Reply #70 on: June 21, 2013, 05:19:18 pm »
Thanks libbydisel.
Tony
i may be incorrect, but i believe the 1.6, and the 1.9idi use the same head studs, but the 1.9tdi uses its own head studs..
could be totally wrong tho.. Andrew, or one of the more TDI-friendly users will chime in and correct me if im wrong  :P
Reply #71June 21, 2013, 06:09:08 pm
« Reply #71 on: June 21, 2013, 06:09:08 pm »
Nah, stock VE TDIs have the same head bolts.
Reply #72June 23, 2013, 09:12:17 am
TonyTDTruck
  • 110
« Reply #72 on: June 23, 2013, 09:12:17 am »
After pulling out all the parts from the block, I saw the rod bearings have this wear pattern. It looks like pre-detonation. Or is it oil starvation? I've seen oil starvation as grooves or pealing of the bearing surface.
Again never seen this in any engine overhaul I've done. This is only after 600 miles of running.
Any body seen this before?
Reply #73June 23, 2013, 11:20:41 am
« Reply #73 on: June 23, 2013, 11:20:41 am »
That doesn't look like my AAZ rod cap or main rod halves. That looks like the bottom cap half as I can't see a rod going through your hand and my AAZ the caps were not threaded. Mine had a locator pin. Also I haven't seen anything like that. It almost looks like it had too much clearance and was pounding the bearing surface. Just a guess, but that is what it kind of looks like.
Reply #74June 23, 2013, 11:24:45 am
« Reply #74 on: June 23, 2013, 11:24:45 am »
http://techtonicstuning.com/main/index.php?main_page=product_info&cPath=2_13_61_251&products_id=464
what you need is 2 others.. 15$ more for 4 extra studs/nuts... makes a 4th set cheap.. if you doing lots of rebuilds may be worth it s you can price by the nut/stud/washer vs over priced kits..
when i see crap like that makes me wanna price other kits in sizes i seek for better deals... they are also selling new rod bolts for a vr6 that are idenitical to tdi strech bolts... but can be reused... i put them in this vr6t project..
