Author Topic: injector nailing or is it a tappet?  (Read 4735 times)
March 14, 2013, 09:21:46 am
paolomarks
  • 146
« on: March 14, 2013, 09:21:46 am »
So I finally got my AAZ back on the road after it threw a rod 6 months ago.  Rebuild included new pistons, one new rod, all new bearings, new head(I used the old guts including the hydraulic lifters)  I took the injectors apart and boiled and cleaned them.  Didn't do anything to the Injection pump since it was working great 6 months ago. It's been sitting for 6 months though with regular diesel fuel in it.
   I have the timing set at .035(.88mm)  I've got clear fuel lines and no bubbles in or out of IP.  Engine starts up pretty quick but runs a bit lumpy when cold (even with cold start cable out)  puts out whitish smoke.  I have an oil pressure gauge and pressure is good.   I've taken it out for a "break in" run and it makes a constant  loud ticking noise , frequency of ticking is related to RPM's.  Sounded like a tappet to me so I checked the lifters as Bentley recommends by seeing whether a .004 feeler gauge can be inserted between cam and lifter right after a warm up run.(rotating the engine over to gain access to all lifters of course)  and then pressing the lifters down with a wooden stick and checking again.  I wasn't able to slip the .004 between , so I think they're fine.
   I'm not sure I know what injector nailing sounds like.  What causes it and how can you pin point the nailing injector?  I've loosened the lines from one injector at a time while engine idles and the rpm's drop about the same for each.  Should I just keep driving it a see if it goes away?
   Thanks in advance, Paolo
Reply #1March 14, 2013, 09:29:20 am
wolf_walker
  • 1205
Re: injector nailing or is it a tappet?
« Reply #1 on: March 14, 2013, 09:29:20 am »
Did the noise go away when you loosened any one injector?
The frequency of the noise will be slightly different if it's on a cam lobe or an injector, but it's hard to explain.
Did the lifters fit and rotate freely in the bore on the new head?
You can probably run some more initial timing, they usually start better with some more.
I start around .90
Mentat Text Two
Reply #2March 14, 2013, 09:47:50 am
« Reply #2 on: March 14, 2013, 09:47:50 am »
I'd probably start with advancing the timing as well. I know it says 0.80mm for the AAZ.. I run mine at nearly 1.02mm and it runs fantastic.
Quote from: Vince Waldon
The Bentley service manuals list the following "official"  settings:
Early Chassis:  (1977-1983)
1.5l non-turbo 1977-1980                                        0.88 +/- 0.05 mm
1.5l non-turbo 1980 with yellow dot                         1.15 +/- 0.05 mm
1.6l non-turbo  1981, 1982, and 1983 pickup            0.88 +/- 0.05 mm
1.6l non-turbo  1983 Rabbit and Jetta                        0.95 +/- 0.05 mm
1.6l non-turbo  1983 Vanagon                                  0.90 +/- 0.05 mm
1.6l tubo diesel (1982-1983)                                       1.00 +/- 0.05 mm
MK2 / A2 chassis:  (1985-1992):
Engine ME (1.6l non-turbo) 1985                             0.95 +/- 0.02 mm
Engine ME (1.6l non-turbo) 1986 and up                 0.90 +/- 0.02 mm
Engine MF (1.6l turbo)                                           1.00 +/- 0.02 mm
Engine 1V  (ECO diesel)                                         1.00 +/- 0.02 mm
MK3 / A3 chassis (1993-1997):
Engine AAZ  (1.9l turbo)                                        0.80  +/- 0.02 mm
Reply #3March 16, 2013, 03:18:17 pm
paolomarks
  • 146
« Reply #3 on: March 16, 2013, 03:18:17 pm »
 I think I've decided that it's a lifter after a simple test.  Tell me if you think this is conclusive.  Test was as follows.  As I coast in gear,  (say 35 mph in 3rd)  I can distinctly hear the tapping, then I turn the key off, effectively closing the fuel solenoid and preventing any fuel entering the injectors.  Result-  Tapping noise is unchanged.  Conclusive?
   I can't really hear the noise at idle, but as I rev it up it becomes more and more audible until it becomes masked by engine noise.   Paolo
Reply #4March 16, 2013, 03:26:02 pm
wolf_walker
  • 1205
Re: Re: injector nailing or is it a tappet?
« Reply #4 on: March 16, 2013, 03:26:02 pm »
Sounds reasonable. Unless it's something else mechanical clacking.
Sent from my SCH-I535 using Tapatalk 2
Mentat Text Two
Reply #5March 20, 2013, 07:30:07 pm
wdkingery
  • 494
« Reply #5 on: March 20, 2013, 07:30:07 pm »
Yeah I like it. My nailing injector noise went away with the exact same test
Reply #6March 22, 2013, 12:28:21 am
shwak23
  • 417
    • Blackdog Junkyard
« Reply #6 on: March 22, 2013, 12:28:21 am »
Not an exhaust leak is it?
Sent from Outer Space!
