Author Topic: Oil pump drive,,  (Read 7047 times)
February 05, 2013, 06:58:47 am
TUFFY
  • 104
Oil pump drive,,
« on: February 05, 2013, 06:58:47 am »
Is there a drop in oil pump drive for a 1.6 without a vacuum pump?  Or has anyone modified a pump drive and cut off the vacuum pump part of it?
Reply #1February 05, 2013, 07:47:49 am
Re: Oil pump drive,,
« Reply #1 on: February 05, 2013, 07:47:49 am »
special pump, gear and cap...
Reply #2February 05, 2013, 12:30:14 pm
« Reply #2 on: February 05, 2013, 12:30:14 pm »
there ARE setups out there to do that, but they are basically unobtanium..
they were only used prior to 1978, and only on 1.5 diesels, with very small pumps..
only part of the setup i have ever seen, is the oil pump..
its basically the same setup used to drive the oil pump on a 16v, but the gears are reverse cut, because the diesel IM shaft spins backwards..
Reply #3February 05, 2013, 12:49:29 pm
« Reply #3 on: February 05, 2013, 12:49:29 pm »
i have the full setup off of a 1.5 but its all at my brothers house or i'd take pictures.  there was recently a thread about this, do a search there was lots of good info.
Reply #4February 05, 2013, 02:22:56 pm
danster
  • 71
« Reply #4 on: February 05, 2013, 02:22:56 pm »
Reply #5February 05, 2013, 04:29:05 pm
« Reply #5 on: February 05, 2013, 04:29:05 pm »
well, hang onto it..
and if you ever end up using it, be sure that you use the 2.0 16v oil pump..
the stock oil pump for that setup has like 22mm gears.. smallest pump ive ever seen..
16v oil pump has 30mm gears..
Reply #6February 05, 2013, 06:15:47 pm
« Reply #6 on: February 05, 2013, 06:15:47 pm »
I think you could just pop the top off the vac pump and pull the vanes out. Reassmble and you woudl have no vacuum being made. You could plug the hole in the barb as well.
Reply #7February 06, 2013, 04:22:57 am
TUFFY
  • 104
« Reply #7 on: February 06, 2013, 04:22:57 am »
The vacuum pumps I have don't have vanes, they have that big diaphragm on them.
Reply #8February 06, 2013, 04:52:26 am
« Reply #8 on: February 06, 2013, 04:52:26 am »
I'm not sure pulling the vanes and plugging the lid is enough.  The oil pressure is restricted by the vanes and if unrestricted, may lower overall oil pressure.
Same question with the early diaphragm version: how much will defeating the pump affect oil pressure. The older may be better... I don't think I have one to check. :-/
Reply #9February 06, 2013, 05:28:15 am
TUFFY
  • 104
« Reply #9 on: February 06, 2013, 05:28:15 am »
I can leave the vacuum pump on, just would look allot cleaner if I could get rid of it. Also give me more room for steering shaft in the tractor if the pump wasn't there.
Reply #10February 06, 2013, 06:37:54 am
« Reply #10 on: February 06, 2013, 06:37:54 am »
I never saw any oil port into the vanes, I thought it ran through to the top and came out that way. Either way, I don't think you would loose 1 psi of pressure. I would think it would be less than 1 main bearing worth of oil.
If you were really worried about oil through vane loss you could take it out and weld the vane area shut and then reassemble.
Reply #11February 06, 2013, 07:11:26 am
« Reply #11 on: February 06, 2013, 07:11:26 am »
AIUI, the vanes are pushed out by the oil pressure and oil is also pushed past the vanes at the top to lubricate and cool the rotating assembly. The excess oil is pushed out of the pump to the crankcase with the air, much like a Mr. Coffee pushes water up to the basket (upside-down).
So, I rekon if the vanes are removed, oil will get pumped into the chamber without the vanes providing any backpressure and it will drain into the crankcase without restriction, other than the diameter of the exit port.
Not sure welding the vane feed shut would be advised, the bearing/bushing may need the lube.
Reply #12February 06, 2013, 07:36:58 am
« Reply #12 on: February 06, 2013, 07:36:58 am »
The vanes are pushed out by the spinning motion. IIRC the oil flows from the top. I also think since it is unfiltered and I think un bypassed oil that it would have no effect on the oil pressure of the engine.
Reply #13February 06, 2013, 08:02:26 am
« Reply #13 on: February 06, 2013, 08:02:26 am »
Do the industrial engines have a vacuum pump?
The vane type pumps are already a lot more compact, if you want to source one of those. Or I suppose if you want to sacrifice a pump you can take it apart and remove the pump part of it and leave the shaft and whatever bearing it has, and weld some sort of cap onto it. I don't see why you couldn't go that route but I've never done it.
Reply #14February 06, 2013, 08:37:49 am
« Reply #14 on: February 06, 2013, 08:37:49 am »
The oil pushes out the top of the stem, but with the lid on, >100psi pressure builds behind the vanes. The vanes are too light to fling anyway.
There is a helical groove on the shaft below the vanes for lubrication that draws oil from the chamber.
I got some pics I'll share later today.
Sorry for the hijack, Tuffy, I'll try to get diaphragm version pics if I have one in the pile.
