Author Topic: Connecting rod bolt and nut,,  (Read 6341 times)
February 03, 2013, 08:26:54 am
TUFFY
  • 104
« on: February 03, 2013, 08:26:54 am »
Anyone know where I can get a rod bolt and nut for a 1.6 diesel? I was putting short block together and found threads on one of the rod bolts are messed up.
Reply #1February 03, 2013, 09:57:03 am
Re: Connecting rod bolt and nut,,
« Reply #1 on: February 03, 2013, 09:57:03 am »
Parts geek??
Reply #2February 03, 2013, 10:02:42 am
TUFFY
  • 104
« Reply #2 on: February 03, 2013, 10:02:42 am »
I ran a die on the bolt and I think it's going to be ok. I see some 1.6 had regular rod bolts and the later one had stretch bolts. I am not sure of the year on the engine, it is a VW replacement engine, the bearings were dated 1996. Are the early and late bolts torqued the same way? 22lbs then a 1/4 turn?
Reply #3February 03, 2013, 10:20:26 am
« Reply #3 on: February 03, 2013, 10:20:26 am »
Arp
Reply #4February 03, 2013, 10:28:10 am
TUFFY
  • 104
« Reply #4 on: February 03, 2013, 10:28:10 am »
I did some searching on here and found info on rod bolts. Hemispherical head on bolt and 15mm long threaded portion is old style bolt torqued to 33 lbs. Conical head on bolt and 25mm long threaded portion is stretch bolt torqued to 22 lbs + 1/4 turn.
Reply #5February 03, 2013, 10:31:58 am
« Reply #5 on: February 03, 2013, 10:31:58 am »
...and single-use.
Reply #6February 03, 2013, 01:44:53 pm
sprstu
  • 99
« Reply #6 on: February 03, 2013, 01:44:53 pm »
McMaster Carr does has a huge selection of bolts, if you can find what youre looking for it would be worth calling them to see whats available.
http://www.mcmaster.com/#
Mk1 caddy TD, mk4 Golf Tdi
Reply #7February 03, 2013, 01:50:07 pm
« Reply #7 on: February 03, 2013, 01:50:07 pm »
Get the correct rod bolts either from VW or the aftermarket ones from ARP.  The shaft is fluted to be a press fit and locating pins for the cap.  There are not any generic McMaster bolts that will work.
Reply #8February 03, 2013, 04:25:39 pm
TUFFY
  • 104
« Reply #8 on: February 03, 2013, 04:25:39 pm »
Mine had the early style bolts. The one with threads a little messed up worked fine after running die over it. It torqued up real solid, didn't feel stretchy or like threads were pulling off bolt. Any one know the ARP part number for the bolts that fit a 1.6? I might get some down the road.
Reply #9February 04, 2013, 01:53:21 pm
wdkingery
  • 494
« Reply #9 on: February 04, 2013, 01:53:21 pm »
man i tell you i know they are TTY bolts but i reused every last one of them, and it has worked well..
Reply #10February 04, 2013, 02:14:39 pm
« Reply #10 on: February 04, 2013, 02:14:39 pm »
when i got mine my parts guy told me u may as well get arp bolts because they are the same price.  i am pretty sure they are the same for almost every 4 cylinder vw mine said they were for a g60 or something.  he also said if its the first time reusing the rod bolts ur probably ok, but if u know the engines been apart before or ur not sure u should just get new ones.  100 bucks worth of bolts can save u alot.
Reply #11February 04, 2013, 03:56:22 pm
Hoble
  • 76
« Reply #11 on: February 04, 2013, 03:56:22 pm »
i have an extra set of ARP rod bolts im trying to sell off
Reply #12February 04, 2013, 05:39:16 pm
audilvr
« Reply #12 on: February 04, 2013, 05:39:16 pm »
be careful using a die to repair threads. they're designed to cut. they will remove thread material making them weaker. a thread chaser won't cut, only reform's the thread.
Reply #13February 05, 2013, 05:57:38 am
Jetmugg
  • 530
« Reply #13 on: February 05, 2013, 05:57:38 am »
I think I have some complete piston/rod assemblies, with bolts, that you are welcome to have if it will help your effort.
Steve.
Send me a PM if I can help.
