If I undo my out bolt, the return drains down by gravity.
Off topic somewhat, but where does one find replacement copper washers, my import supplier could not find the ones I need for my oil return thanks.
Yeah I know. However what you are getting at does not pertain to what I said earlier. We are not talking about over night drain back, we are talking about a leaking OUT banjo.There is pressure in that line while running.. The fuel pump is pushing nearly as much fuel back to the tank as it brought from it in the first place.
Consider the diameter of the orifice in the OUT bolt and the ID of the return line itself.
That is incorrect. The crush washers are outside the OUT bolt and so see zero pressure. .....
