Author Topic: k14-2 vs k14 vs k24 pics  (Read 34623 times)
Reply #15January 19, 2013, 09:02:54 am
Re: k14-2 vs k14 vs k24 pics
« Reply #15 on: January 19, 2013, 09:02:54 am »
yeah and a bunch of different k24's too and even more k26's.  i try to be really specific on which one im talking about alteast with t3's anyway since there is 35, 40, 45, 50, 55, 60, and super 60 trims of t3 and about 20 different exhaust housings.
Reply #16January 20, 2013, 06:33:34 pm
sprstu
  • 99
« Reply #16 on: January 20, 2013, 06:33:34 pm »
here is my aaz K14
« Last Edit: January 30, 2013, 04:47:53 pm by sprstu »
Mk1 caddy TD, mk4 Golf Tdi
Reply #17January 20, 2013, 09:52:12 pm
RustyCaddy
  • 395
« Reply #17 on: January 20, 2013, 09:52:12 pm »
Does the AAZ K14 use 3 brackets and 6 bolts to hold the turbo to the housing?
Reply #18January 25, 2013, 10:08:36 am
sprstu
  • 99
« Reply #18 on: January 25, 2013, 10:08:36 am »
If youre asking about the compressor side then yes, there are 6 bolts and 3 brackets. You can see 2 of the 3 in the second picture.
Reply #19January 25, 2013, 07:16:51 pm
RustyCaddy
  • 395
« Reply #19 on: January 25, 2013, 07:16:51 pm »
Thank you Sir!!
i have a K14 off a ecodiesel that has a housing ruined with rust holes...bought a K14 housing without the turbo and found the difference from the 4 bolt/two bracket style of the little K14 i removed from the eco-housing (i didn't get the 3 brackets...damn).  Wish i could have gotten the rest of the big K14 too.
The wastegate part number is the same for both kind of turbos BTW...i need to measure the hot sides but they look the same.
Reply #20January 25, 2013, 07:35:01 pm
« Reply #20 on: January 25, 2013, 07:35:01 pm »
Thank you Sir!!
the K14 on the EcoDiesel is smaller than the rest of the K14s..
you gotta use K14 eco parts if you have a K14 eco turbo..
or else use the compressor wheel, housing, backing plate, and hardware to attach the standard (bigger) K14 cold side to the K14 eco CHRA, if the bolt pattern on the center housing is the same on both turbos..
i dont know how much of a difference it is between the K14 standard, and K14 eco wheels, but i DO KNOW that there is a difference..
Reply #21February 10, 2013, 09:22:03 am
dts67
  • 68
« Reply #21 on: February 10, 2013, 09:22:03 am »
I have used the k14-2 from mercedes om60 on my old car (pug xud), the same as mjf, dont know if it helps but heres the wheel sizes of both rough measured by me, with standard 1.9xud k14 hotside and k14-2 cartridge it made full boost at 3k rpm and the car wasnt the best when dyno'd although still made 173bhp at crank.
Turbine:
xud k14 i=49mm e=42
606 k14-2 i=52mm e=48
Compressor:
xud k14 e=50mm i=32mm
606 k14-2 e=60mm i=43mm
Reply #22February 10, 2013, 09:28:07 am
bbob203
  • 1789
« Reply #22 on: February 10, 2013, 09:28:07 am »
Turbine:
xud k14 i=49mm e=42
Compressor:
how much boost?
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #23February 10, 2013, 09:56:03 am
dts67
  • 68
« Reply #23 on: February 10, 2013, 09:56:03 am »
Turbine:
xud k14 i=49mm e=42
Compressor:
how much boost?
On dyno around 30psi but only because it was unregulated at the time, I got a fair bit more fuel in and better spool at a controlled 30psi but never dyno'd again.
Reply #24February 10, 2013, 11:30:09 am
« Reply #24 on: February 10, 2013, 11:30:09 am »
Inducer and exducer size of the k14-2 are really good.
Reply #25February 11, 2013, 03:17:35 pm
carrizog60
  • 978
« Reply #25 on: February 11, 2013, 03:17:35 pm »
are volvo and mercs k14-2 the same?
Portugal
Reply #26February 11, 2013, 04:14:11 pm
« Reply #26 on: February 11, 2013, 04:14:11 pm »
No idea.  The only thing that could possibly make it not ideal is if it has a very high tip height or a fin design that isn't good for high boost but being that its from a diesel Engine it is probably good,  but it's hard to say with out actually seeing a compressor map
Reply #27February 15, 2013, 11:43:27 am
stewardc
« Reply #27 on: February 15, 2013, 11:43:27 am »
Left is the K-14 I took off my AAZ, right is the Garrett T3 I installed.
Reply #28February 17, 2013, 04:18:33 am
carrizog60
  • 978
« Reply #28 on: February 17, 2013, 04:18:33 am »
compressor:
inducer:37
exducer:55
turbine:
inducer:42
exducer:50
Portugal
Reply #29April 04, 2013, 03:09:53 pm
carrizog60
  • 978
« Reply #29 on: April 04, 2013, 03:09:53 pm »
so how this compare with other common used turbos like stock k24,mercedes t3 and such?
how much can i expect from this turbo?
Portugal
