Author Topic: 2 questions.  (Read 17421 times)
Reply #15December 29, 2012, 06:37:39 am
Re: 2 questions.
« Reply #15 on: December 29, 2012, 06:37:39 am »
AUG trannyis what you want. came off of certain aaz powered cars
http://www.scirocco.org/gears/
ACN is the 'prefered' box for something you can buy without messing with it for a TD. I think it should bolt into mk1 and mk2. If you have mk1 then FF or FN are the ones to go for.
Reply #16December 30, 2012, 11:18:54 am
DogDiesel
  • 210
Re: 2 questions.
« Reply #16 on: December 30, 2012, 11:18:54 am »
Have a 3:67 ASF with .75 removed and .71 installed.
Still rev'd to high for my AAZ.
Added 155x15 tires and now my 55mph rpm is 2450.
Overall drop of 600 rpm over the FF.
Don't have to downshift due to power loss.
Caddy will pull cruise control at any speed in 5th above 35 without drooping on grades.
Driveability and smoothness improvement very noticable.
Wayne
Reply #17December 30, 2012, 12:57:18 pm
Re: 2 questions.
« Reply #17 on: December 30, 2012, 12:57:18 pm »
I have a 3.94 / .71 7A trans on my AAZ, it is not by any means to high of RPM. It also runs a 175-70-13 tire.
Reply #18December 30, 2012, 03:02:29 pm
tyb525
  • 183
Re: 2 questions.
« Reply #18 on: December 30, 2012, 03:02:29 pm »
I have a 4-speed GP trans in my '81, I know a lot of people hate 4 speeds but I don't mind it, I don't expect my NA to be a sports car :D if you are into wide-ratios this is it. 3.89 final and 0.71 4th, gives me about 3000 rpm at 75 MPH with 155/80/13 donuts. I'd like try a 5 speed in my car just to see how much better it is though.
2004 Golf BEW, '81 1.6 NA rabbit (soon to be parted out)
Reply #19December 30, 2012, 04:45:51 pm
Re: 2 questions.
« Reply #19 on: December 30, 2012, 04:45:51 pm »
I have the later FF in my Rabbit with a 1.6TD and find it plenty tall.  With stock tires it will go over 40 in second gear...  3,000 rpms @ 75 MPH.  Sounds good to me...
Reply #20December 30, 2012, 05:12:51 pm
mystery3
  • 774
Re: 2 questions.
« Reply #20 on: December 30, 2012, 05:12:51 pm »
Do you find the gap between fourth and fifth to be excessively large? I run 185/60r14.
Reply #21December 30, 2012, 06:44:11 pm
Re: 2 questions.
« Reply #21 on: December 30, 2012, 06:44:11 pm »
It is not that large in the FF, I drove one of those trannies on a 1.6 NA and it did alright.
Reply #22December 30, 2012, 07:02:43 pm
  • 4549
Re: 2 questions.
« Reply #22 on: December 30, 2012, 07:02:43 pm »
What is the profile on these?  40?  That is the only way I get close to the RPM stated here.
What vehicle ever got the 4.25 final ratio trans code AVX?  Seems like you could pull a nicely loaded trailer with that dude in there.
Reply #23December 30, 2012, 07:11:36 pm
tyb525
  • 183
Re: 2 questions.
« Reply #23 on: December 30, 2012, 07:11:36 pm »
Your tire should be 155-?-15, you need that middle number to determine the diameter (height) of the tire.
Reply #24December 30, 2012, 07:13:05 pm
Re: 2 questions.
« Reply #24 on: December 30, 2012, 07:13:05 pm »
AVX was an ecodiesel only trans wasn't it?
Reply #25December 30, 2012, 07:13:18 pm
Re: 2 questions.
« Reply #25 on: December 30, 2012, 07:13:18 pm »
Jetta ECO.
Reply #26December 30, 2012, 07:34:10 pm
tyb525
  • 183
Re: 2 questions.
« Reply #26 on: December 30, 2012, 07:34:10 pm »
Seems like it would be good for in-town stop and go (lower gearing, less power to get going), but too high rpm for the highway
Reply #27December 30, 2012, 07:35:31 pm
Re: 2 questions.
« Reply #27 on: December 30, 2012, 07:35:31 pm »
Only 3-400 rpm higher than a 3.67 FD with the same .75 5th gear.
It doesn't really make a huge difference.
This same trans on a 2.0L 16v.. OMFG. 4th gear would be balls to the walls.
Reply #28December 31, 2012, 04:35:09 pm
Re: 2 questions.
« Reply #28 on: December 31, 2012, 04:35:09 pm »
I have no complaints.
Reply #29December 31, 2012, 05:46:34 pm
Re: 2 questions.
« Reply #29 on: December 31, 2012, 05:46:34 pm »
Never in Canada. AUG was a MK2 tranny.
