Author Topic: Crank Stud??  (Read 1788 times)
September 21, 2012, 03:43:44 pm
ein bora
  • 377
Crank Stud??
« on: September 21, 2012, 03:43:44 pm »
I've read some information on using a M14X1.50x33 hardened stud as a replacement to the typical crank stretch bolt.
Does anybody know if this actually works?
I've read lots on the theory that it should work, but nothing if it actually did.
http://www.bildon.com/catalog/DetailsList.cfm?ID=M14.DE.Stud&Nav=10&SubNav=none
If you can't take advice - then you can't be helped!
Reply #1September 21, 2012, 05:29:25 pm
CrazyAndy
  • 739
Re: Crank Stud??
« Reply #1 on: September 21, 2012, 05:29:25 pm »
I think it could, but some questions lurk in my mind:
1. Will the stud length interfere with the crank pulley/harmonic balancer/frame horn?
2. Will the corresponding nut be of equal hardness?
3. Will said nut have a seat and/or thick washer under it(THIS IS IMPORTANT; assures even torque force distribution across the face of the crank cog)?
4. What issue will/may be solved going this route?  Helping keep torque on keyway cranks?
