Author Topic: exhaust studs keep braking  (Read 5157 times)
September 10, 2012, 05:47:59 pm
jeff115
  • 19
« on: September 10, 2012, 05:47:59 pm »
is it common for the exhaust studs to brake? the four studs on the two passenger side ports brake all the time, usually in less than 500 miles? ???
Reply #1September 10, 2012, 06:32:00 pm
Re: exhaust studs keep braking
« Reply #1 on: September 10, 2012, 06:32:00 pm »
no, not common....
Reply #2September 10, 2012, 07:32:05 pm
« Reply #2 on: September 10, 2012, 07:32:05 pm »
Depends where you are buying your parts from ::)
NA or TD?
Reply #3September 10, 2012, 07:36:32 pm
« Reply #3 on: September 10, 2012, 07:36:32 pm »
warped manifold???
Reply #4September 10, 2012, 07:37:57 pm
hillfolk'r
  • 1532
« Reply #4 on: September 10, 2012, 07:37:57 pm »
whatcha got...a turbo or na?...id try getting the correct nuts and washers and replace all the studs...maybe tq them from the center to outwards also...hey didnt rabbits have a tie strap to hold the exh manifold to the intake manifold also...im just making suggestions cause im not sure if its turbo or na...ive never seen one warped and cause that probl,em tho
Throttle cables ftw
Reply #5September 10, 2012, 10:51:27 pm
mystery3
  • 774
« Reply #5 on: September 10, 2012, 10:51:27 pm »
They usually only break when you're trying to remove your exhaust manifold, this sounds like it's happening while you're driving which is not common. How are your engine mounts? Are you missing any or all of your exhaust hangers?
Reply #6September 11, 2012, 06:14:12 pm
jeff115
  • 19
« Reply #6 on: September 11, 2012, 06:14:12 pm »
its a td, exhaust hangers in place, correct washers in place, vw studs, the manifold is straight, but not stock its an ebay with t3 footprint.  ???this thing is starting to frustrate me. I love the car but changing the studs all the time is getting old, and this time a couple broke off flush with the head. so Im not sure how to get those out?
Reply #7September 11, 2012, 06:17:42 pm
« Reply #7 on: September 11, 2012, 06:17:42 pm »
Reply #8September 11, 2012, 06:37:01 pm
« Reply #8 on: September 11, 2012, 06:37:01 pm »
So, basically you have a T3 hanging straight off the back of the engine.  Did you add a brace to triangulate it to the block?
Reply #9September 11, 2012, 06:53:26 pm
jeff115
  • 19
« Reply #9 on: September 11, 2012, 06:53:26 pm »
that's a great way to get them out. that makes me happy.
yes there is turbo just hanging off the back..... its usually the bottom studs that break though, and I don't think that baby guy is enough to break any thing any way
Reply #10September 11, 2012, 07:06:47 pm
« Reply #10 on: September 11, 2012, 07:06:47 pm »
Maybe try not to tighten them too much and not bottom out the studs when installing.
Reply #11September 11, 2012, 07:18:40 pm
shwak23
  • 417
    • Blackdog Junkyard
Re: Re: exhaust studs keep braking
« Reply #11 on: September 11, 2012, 07:18:40 pm »
Someone should post pictures of said brace to block. I lose exhaust studs frequently.
Sent from my DROID X2
Reply #12September 11, 2012, 07:25:51 pm
jeff115
  • 19
« Reply #12 on: September 11, 2012, 07:25:51 pm »
ill try not bottoming them out, I dont think Im tightening them to tight? they are so tiny that im scared to tighten them to much so alot of the time they come loose too.
Reply #13September 11, 2012, 07:32:34 pm
« Reply #13 on: September 11, 2012, 07:32:34 pm »
I am sure, Germans being Germans they probably have a torque spec in the bentley. I regretfully can say I never have used it.
Reply #14September 11, 2012, 07:43:23 pm
jeff115
  • 19
« Reply #14 on: September 11, 2012, 07:43:23 pm »
oh good call. ill look fro that spec. but im thinking some 10mm studs- might have to do some clearance work with a die grinder, and a brace from bellow.  if its way over built it usually works right?
thanks for the ideas/advise guys!
