Author Topic: downpipes  (Read 4742 times)
April 11, 2012, 04:58:28 pm
One_punchmachinegun
  • 261
downpipes
« on: April 11, 2012, 04:58:28 pm »
Anyone making downpipes for Mk2 anymore, i have a k24 turbo and looking for 2 1/2 - 3 inch downpipe with a flex at the end, i would attempt to make my own but lack the welding skills and tools. Really down feel like running stock. Just let me know.
“If anyone hears my words but does not keep them, I do not judge that person. For I did not come to judge the world, but to save the world." Jesus Christ
Reply #1April 11, 2012, 05:44:54 pm
Blocksmith
  • 261
    Wrench Lurker
Re: downpipes
« Reply #1 on: April 11, 2012, 05:44:54 pm »
$170 flux core welder from ebay, + a flange, and pipe of whatever diameter you want. Total cost, ~$225 (assuming you either already have or can borrow a welding hood), but you own a welder at the end. It's what I did for my rabbit  ;D
Or, alternatively, find somebody in the area who'll be your friend and let you use their welder. Beer does wonders.
Stock dp's just suck soooo much.   ::)
I would make you one, but I don't have YOUR mk2 handy for test fitting. At least for me, exhaust systems are kind of in the 'cut to fit' category..
Green 83 Rabbit 4dr, 5 speed ACH trans swap, ported 1.6D mech lifter w/ vnt15, na pump w/ gov mod, gasser intake mani, 2.5" exhaust, bilstein sports and cut mk2 springs, ss brake lines, 14" vw bottlecaps
Reply #2April 11, 2012, 06:02:34 pm
billybobf
  • 318
Re: downpipes
« Reply #2 on: April 11, 2012, 06:02:34 pm »
Im sure someone would be happy to make you one depending on your LOCATION.
I have a nice mig welder, would have no problems making you what your looking for.
Reply #3April 11, 2012, 07:00:07 pm
bbob203
  • 1789
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #4April 11, 2012, 07:33:44 pm
CrazyAndy
  • 739
Reply #5April 11, 2012, 11:19:09 pm
One_punchmachinegun
  • 261
Re: downpipes
« Reply #5 on: April 11, 2012, 11:19:09 pm »
correct ;D ^
Yeah, im in Pa(USA) dont know if someone in pa has the tools to do a downpipe, i was thinking of attempting myself after getting the supplies. Now would i just make something that is similar to stock setup? same-ish layout and bends?
Little off subject but i just clocked my turbo and i am curious if the compressor side is to close to the exhaust manifold or would there be no issue?
Reply #6April 12, 2012, 05:15:29 am
bbob203
  • 1789
Re: downpipes
« Reply #6 on: April 12, 2012, 05:15:29 am »
ah i see. i like that andy to bad its  400 dollars. i guess ill keep my terlit bowl.  :'(
03 Jetta wagon TDi
Reply #7April 12, 2012, 06:03:26 am
Trips_B
  • 57
Re: downpipes
« Reply #7 on: April 12, 2012, 06:03:26 am »
I got all my supplies from Colombia river mandrel bending all 2.5" and even the t3 flange.  Whichever flange you get it may have to ground down around the edges.
i used the following
1 u-pipe
1 - 18 degree bend
3 - 45 degree bends
1 - 90 degree bend
Approx 10 feet of straight pipe
Then remove all your stock pipe and use it to mock up all your cuts and wells away.  I have a bunch of pics at home i can upload later today.  I missed the flex pipe for some reason or another. I knew i needed it but i just got carried away.
an issue you may have with "clocking the turbo is clearance with your intake manifold
Reply #8April 12, 2012, 07:57:59 am
Re: downpipes
« Reply #8 on: April 12, 2012, 07:57:59 am »
1 u-pipe
1 - 18 degree bend
3 - 45 degree bends
1 - 90 degree bend
where you loacted Trips? i would assume somewhere in the 503 since your referring to columbia river mandrel..
Reply #9April 12, 2012, 08:22:55 am
Trips_B
  • 57
Re: downpipes
« Reply #9 on: April 12, 2012, 08:22:55 am »
Negative, im located in the 604  :) Vancouver, BC Canada
Everything here is way overpriced, also not being able to drive meant that everything I needed had to be shipped.  Colombia river had decent prices and shipping, as well there customer service was very good.
OP, definitely do a test fit with your intake manifold before you torque up up turbo.  When I clocked my turbo for my IC piping I had the grind the intake mani and a/r housing.
As well make sure you use a high quality silicone coupler on your a/r inlet as its pretty darn close to the exhaust mani
Reply #10April 12, 2012, 08:24:09 am
Re: downpipes
« Reply #10 on: April 12, 2012, 08:24:09 am »
you mind PMing me the details for columbia river mandrel? or atleast a phone number?
Reply #11April 12, 2012, 09:20:15 am
Blocksmith
  • 261
    Wrench Lurker
Re: downpipes
« Reply #11 on: April 12, 2012, 09:20:15 am »
What? R.O.R. haz no Google-fu skillz??   :D ;) ;D
http://www.mandrel-bends.com/catalog/
Reply #12April 12, 2012, 09:32:08 am
Re: downpipes
« Reply #12 on: April 12, 2012, 09:32:08 am »
thought about that AFTER i posted the request..
lmao..
thanks Trips..
Reply #13April 12, 2012, 11:08:11 am
One_punchmachinegun
  • 261
Re: downpipes
« Reply #13 on: April 12, 2012, 11:08:11 am »
do you mean getting the manifold to fit on the head or the piping to go to the compressor? Because i'm foing custom intercooling piping.
And thank you for the info on the piping, the ten feet of straight pipe was for downpipe back right? Pictures arent needed if its a hassel, but would help. Thank you guys, i have decided to do it myself, turns out my wife's uncle runs a rent-a-center and have a welder, so i should be able to do it. Will have to practiace a lot though.  ::)
Reply #14April 12, 2012, 12:19:57 pm
shwak23
  • 417
    • Blackdog Junkyard
Re: Re: Re: downpipes
« Reply #14 on: April 12, 2012, 12:19:57 pm »
1 u-pipe
1 - 18 degree bend
3 - 45 degree bends
1 - 90 degree bend
Post your pics. Quit holding out on us. Lol
Sent from my DROID X2
