Author Topic: my 1.6L rebuild and upgrade  (Read 20241 times)
Reply #30February 12, 2006, 12:32:30 pm
16V-Sauger
« Reply #30 on: February 12, 2006, 12:32:30 pm »
hmpf, no one else did that before?  :shock: omg :lol:
Reply #31February 12, 2006, 01:51:05 pm
935racer
« Reply #31 on: February 12, 2006, 01:51:05 pm »
I've never heard of anyone trying it.
I am glad youa re so I can know for sure though :D
The reason I have never tried is because I don;t think gasser rods or pistons or crank or block would last very long at all. Especially if you tried to put any power though it. I would love for someone to prove the wrong though get to it man :twisted:
Reply #32February 12, 2006, 02:21:47 pm
16V-Sauger
« Reply #32 on: February 12, 2006, 02:21:47 pm »
i definately will  :lol:
every high-stressed engine has long rods, best way would be to use 159mm rods. but i have no tall-block.  :oops:
stock rods from a rs2 were able to handle 90PS per rod. even if its not the same if they were used in a 1.8L 16VT with 360PS i think that stuff sould easily handle ~120hp. thats what i would like to reach, with many torque  :twisted:
Reply #33February 12, 2006, 07:04:40 pm
HP
  • 225
« Reply #33 on: February 12, 2006, 07:04:40 pm »
Man, I know u'r car! From the Internet. I even hav those 2 last pics saved on my disk for almost a year now!!  :lol:  :lol:  funny..
Crazy project u got in hands!!  :twisted:  Good luck
About the interiors, could u please tell me wot's all those buttons?? The "SSA" and the "CHECK" ones! Also the two "freeze" buttons on the left!  (I wonder..  :roll:  )
Is the MFA and Cruise-control working?? How did do u do that??
The only thing I don't like is the steering wheel. I prefer the stock ones much better (especially with leather!).  :)
U hav one of the best Golf II turbodiesel I'v ever seen!!  :P  Congrats!
Reply #34February 13, 2006, 01:53:17 am
16V-Sauger
« Reply #34 on: February 13, 2006, 01:53:17 am »
thanks man  :D
that mfa mod was one of the trickiest things i've ever done. it was about ten hours of soldering very tiny cables to even more tiny connection points. at the end it looked like this:  :lol:
that freeze button was used to manually turn the A/C on and off. that was a time when i did not know that in the US there is a special switch just for that use, even it has a german partnumber it can NOT be ordered in germany :evil:  :oops: . it took me around one year to get such a switch and finally i got it :D
that SSA unit is something really special. its the only car i have found with that unit, even it is was not delivered with that thing. it was used short time to reduce the emissions and the fuel consumption of a car by turning the engine off, e.g. while staying at a red traffic light or something. to start the engine again you only have to put the "gear-level" into first gear position and the engine will start automatically. very interesting while cruising in cities.
that check-switch is again from US, but can be ordered even in germany, it was normally used in GTI's to give a hint when the engine respectively the O2 sensor gets bad. i now use it to check the failure-storage from the ABS.
mfa and cruise-control ARE working fine  :D i just have to re-wire the seat-heating and the SSA needs some time to get completely together.
that pictures are very old, the car has now red/white US-taillights, white US-sidemarkers in the fender and the 1985 square US-headlights
Reply #35February 13, 2006, 03:36:07 am
16V-Sauger
« Reply #35 on: February 13, 2006, 03:36:07 am »
so i think its time for some measurements and comparison :)
i'll compare the diesel stuff to the G60, because they have the same rod-lenght...
Diesel:
rod        713gr
wrist pin 169gr
piston     454gr
thinnest part at the piston 9,6mm
G60:
rod 694gr
wrist pin 130gr
piston 396gr
thinnest part at the piston 8mm
parts i will use:
rod 660gr
wrist pin 99gr
pistons (aren't available at the moment)
so that dieselstuff is really heavy, i wouldn't like to rev that past 6000.
Reply #36February 13, 2006, 04:35:00 am
16V-Sauger
« Reply #36 on: February 13, 2006, 04:35:00 am »
i'm actually siting in front of the diesel head and i'm debating with myself if to use the stock cam or one of these 10.8mm lift gti cams...
so, maybe someone can help me out:
is a gti cam worth it? i have it, the only thing to do is to make a mountable pulley  :oops: and thats what i really don't like very much
Reply #37February 13, 2006, 08:08:15 am
HP
  • 225
« Reply #37 on: February 13, 2006, 08:08:15 am »
Quote from: "16V-Sauger"
u can't  turn the A/C off without that switch??!! :shock:  I'm a bit confused! :?
That's awsome!!  :P That's originally from the Diesel Strom Concept. I'v read about it. :)
Reply #38February 13, 2006, 09:18:21 am
16V-Sauger
« Reply #38 on: February 13, 2006, 09:18:21 am »
Quote from: "HP"
normally you turn the A/C on and off when pushing that lever above the temperatur-selection, right? i used to drive with that lever in right position and thats when the A/C ist turned on automatically. so i put that switch into the electrical curcuit and know i can switch ich on and off when i want  :D
also i have another update while the pistons are on there way... i hope you like it  :D
i definately do  :twisted:
Reply #39February 15, 2006, 06:30:46 pm
chrissev
  • 694
« Reply #39 on: February 15, 2006, 06:30:46 pm »
this is funny.  over here across the pond we spend a lot of our time modifying our VWs to look European (many people change the square US headlights in their rabbits and golfs for the round european type). And meanwhile there you are modifying a perfectly European looking Golf to look like a US golf!
Reply #40February 16, 2006, 11:58:40 am
16V-Sauger
« Reply #40 on: February 16, 2006, 11:58:40 am »
by now you can see many cars from the netherlands, germany, belgium... with your US-stuff :)
and i also heard that many us cars were modded to european style  :D
Reply #41February 16, 2006, 12:07:30 pm
HP
  • 225
« Reply #41 on: February 16, 2006, 12:07:30 pm »
That's very normal. Because people usually like to have their cars exclusive and original, they will try to find rare parts for their vehicule. Therefore, NA-style in Europe and Euro-style in NA.
Reply #42April 13, 2007, 03:11:30 am
lusob
  • 9
« Reply #42 on: April 13, 2007, 03:11:30 am »
Can you repeat photos with MFA, becuse they aren't working now? I want install MFA in my car but i can't find any informations. Please
