Author Topic: Stock fuel pipe size?  (Read 3826 times)
January 16, 2012, 02:12:27 pm
Bugsy_malone 666
  • 178
« on: January 16, 2012, 02:12:27 pm »
does anyone know what the internal size of stock fuel line is on the diesels? or what size the barbs take?
I am about to start replacing a large number of diesel lines and want to buy a big roll and the right adaptors in the case of returns which might not need to be as big.
Cheers :)
Reply #1January 16, 2012, 02:22:59 pm
Re: Stock fuel pipe size?
« Reply #1 on: January 16, 2012, 02:22:59 pm »
i wanna say the feed is 5 or 6mm, because 1/4 inch fuel hose is a bit large..
Reply #2January 16, 2012, 02:44:14 pm
Bugsy_malone 666
  • 178
« Reply #2 on: January 16, 2012, 02:44:14 pm »
I was going to go with 6mm, 1/4" is 6.35mm ;) so it is a bit larger! the really odd thing about my current setup is I am sure some of the lines I used previously are bigger, because the fuel filter from a vanagon has 8mm in/out steel pipe, but I am sure its 6mm from the fuel tank.
I guess I'll just order in a load of 6mm and see how it goes, I'll wait to see if anyone else has any other ideas, most importantly I dont want to go too small, if its 8mm and I put 6mm in thats going to put a bit more stress on the pump sucking through a thinner straw!
Reply #3January 19, 2012, 11:41:41 am
badersbus
« Reply #3 on: January 19, 2012, 11:41:41 am »
We used 10mm to feed the hard pipe at the IP and 6mm return from the hard pipe at the IP.
10mm is a bit large , but works fine.
Noticed you are in the UK
Cheapest i could find when i was looking , it does say petrol pipe , but they assured me it was ok for diesel , which it seems to be on my lads Caddy
http://www.beal.org.uk/hoses-tubing-fittings/tubing-hoses/cat_36.html
Reply #4January 19, 2012, 10:12:16 pm
  • 2926
« Reply #4 on: January 19, 2012, 10:12:16 pm »
Depends on what car you are talking about.
 I've used 5/16" brake line to replace Rabbit fuel lines under the car... 8mm.
 The plastic ones under a MK2 look thinner.
Reply #5January 20, 2012, 10:23:59 am
« Reply #5 on: January 20, 2012, 10:23:59 am »
they are way thin..
Reply #6January 20, 2012, 05:31:52 pm
Bugsy_malone 666
  • 178
« Reply #6 on: January 20, 2012, 05:31:52 pm »
hmm wish I'd had this before I ordered! Its rare to actually see it cheaper than I can get it on ebay, I paid about £14 for for 10m of 'unleaded' petrol hose, which I bought instead of 'fuel/oil' hose because I believe unleaded petrol has a bit more bite to it than other fuels like diesel, as a result i figured food safe oils running through lines that should withstand nasty petrol should be fine!
I have gone with 6mm in the end, landrover fuel lines for the 2.25litre petrol are 6mm, vw beetle/camper petrols are 5mm and even our tractors(1960s) I am pretty certain they are about 6mm (probably 1/4").
Interestingly I have bought a big double filter unit for my second oil tank and surprisingly between the 2 filters the actual drilled holes cant be much more than 6mm at best, so I am glad I havent over spec'd the lines based on that.
Reply #7January 22, 2012, 05:26:04 pm
GEE-BEE
  • 1604
« Reply #7 on: January 22, 2012, 05:26:04 pm »
7MM
GERMANAUTOSUPPLY.COM
https://www.germanautosupply.com/store/
he is carring my breather for the vw buses and vanagon
I have done over 70 obsolete hoses now
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
