Author Topic: TD: Block oil drain?  (Read 4321 times)
November 20, 2011, 07:27:39 pm
monomer
  • 414
« on: November 20, 2011, 07:27:39 pm »
Anyone have pics of a tapped block for the turbo's oil drain?
I really do not want to drill the pan, I plan on doing autocross and the drain should never have to fight the oil in the pan.
Just need to know where to drill/tap
www.michiganvw.org
Reply #1November 21, 2011, 04:33:08 am
Re: TD: Block oil drain?
« Reply #1 on: November 21, 2011, 04:33:08 am »
IIRC the 1.9 aaz and all the TDI's have a tapped block from the factory. Maybe find a pic of them or I could get one this evening.
Reply #2November 21, 2011, 02:21:01 pm
« Reply #2 on: November 21, 2011, 02:21:01 pm »
They changed a lot on the block of the 1.9s and the area is raised up. I would sooner tap the pan than weaken the block. If you add the AAZ breather to the front of the engine where the lift pump is designed to go you shouldn't have any problems. I don't think you would have any anyways though unless you overfill the pan.
Reply #3November 21, 2011, 02:52:23 pm
BlueMule
  • 51
« Reply #3 on: November 21, 2011, 02:52:23 pm »
Mon, BYM is correct, the drain is above the oil level. I guess it could slosh high enough in a turn, or braking condition to get up around the drain, but never enough to for a long term blockage condition. I also agree that drilling into a block may not be the best idea, especially if you are pushing the engine, (govoner mods etc). Blocks flex, twist and do all sorts of strange things when design limits are pushed.
BlueMule
BlueMule
A.S.E. Master Since 1986
Nissan Master Since 1995
Auto Tech Since 1975
Totally Ignorant When It Comes To MY
'86 Golf TD
Reply #4November 21, 2011, 03:33:10 pm
monomer
  • 414
« Reply #4 on: November 21, 2011, 03:33:10 pm »
BlueMule
Noted, I'll just go with a braided line to the back of the pan.
Now, to source the fittings for my t25's drain/inlet...
www.michiganvw.org
Reply #5November 21, 2011, 06:40:01 pm
« Reply #5 on: November 21, 2011, 06:40:01 pm »
As much as I hate to endorce them Black forest industries is selling a pan that has 1/2 NPT female already welded to it. I would do that route as the pan I have likes to leak around where I welded. Good penatration up near the top of the pan pulled it down quite a bit.
BTW I also adapted JIC fittings to work with everything else and they don't leak a drop. Very reusable.
Reply #6November 22, 2011, 09:17:01 am
« Reply #6 on: November 22, 2011, 09:17:01 am »
I believe the mk3 oil baffle will fit in place of your stock oil baffle. The newer is larger and flatter and should help control the oil better in corners.
Reply #7November 25, 2011, 06:43:43 pm
monomer
  • 414
« Reply #7 on: November 25, 2011, 06:43:43 pm »
got a link for that pan?
JIC or A/N flairs all the way.
edit: found it http://yhst-1918367471896.stores.yahoo.net/hdturbooilpan.html
www.michiganvw.org
Reply #8November 26, 2011, 07:58:20 am
« Reply #8 on: November 26, 2011, 07:58:20 am »
JIC are easy to find at most any hydro shop. The A/N fittings that you get from summit are all aluminum peices of crap IMO. They need not make a fitting you are trying to reuse out of aluminum that is so soft. I have seen they make some differently but are even more expensive.
Reply #9November 27, 2011, 12:45:49 pm
monomer
  • 414
« Reply #9 on: November 27, 2011, 12:45:49 pm »
I'm in and out of a parker store once a week for work.
They sell earl's there, but I'm going with normal, industrial NON RED AND BLUE stuff.
I've seen plenty of JIC fitted stuff fail. Usually hardlines without proper support and 90 degree bends. Granted, everything at the shop is 2000+psi. I think It'll be proper on the car....
www.michiganvw.org
Reply #10November 28, 2011, 06:03:20 pm
nathan_b
  • 361
« Reply #10 on: November 28, 2011, 06:03:20 pm »
911s use an electric pump ?fuel pump? for suction of oil out the drain
Reply #11December 01, 2011, 10:51:50 pm
levi20AE
  • 47
« Reply #11 on: December 01, 2011, 10:51:50 pm »
i took the pan of and drilled a hole in the back of the block on my 1.6NA when installing a factory turbo setup.  I used a stainless NPT to -10 AN fitting as a oil return into the block.  It works nice because you can use the factory hardline portion of the turbo return line to weld a steel -AN bung on to.
Reply #12December 02, 2011, 12:07:34 pm
Toby
  • 728
« Reply #12 on: December 02, 2011, 12:07:34 pm »
The way to prevent welded bungs from leaking is to weld them from the outside and then braze them from the inside to seal any porosities. Or just braze the bung to the pan.
