Author Topic: How the hell do you get the camgear off???  (Read 9443 times)
Reply #15November 09, 2011, 02:42:20 pm
Mark(The Miser)UK
  • 1557
Re: How the hell do you get the camgear off???
« Reply #15 on: November 09, 2011, 02:42:20 pm »
Use a hammer from behind.
Hit the tin. Remove little hex socket bolt that holds the tin still first, then the tin is free to flex up to the pulley.
Bolt only needs a couple of turns slackening, else some have apparently knocked the end off a cam :o
Mark-The-Miser-UK
Reply #16November 09, 2011, 04:06:05 pm
« Reply #16 on: November 09, 2011, 04:06:05 pm »
Let's not talk about that........ :'(
Reply #17November 11, 2011, 05:42:41 am
92EcoDiesel Jetta
« Reply #17 on: November 11, 2011, 05:42:41 am »
Hit the tin? And end up with a bent and dented tin that won't look right forever after? Was that said with tongue in cheek? :P
Reply #18November 11, 2011, 07:25:20 am
Toby
  • 728
« Reply #18 on: November 11, 2011, 07:25:20 am »
It won't dent the tin. Its laid up tight to the cam gear. It does not take a hard blow, just a sharp one to remove the cam gear. You are not driving railroad spikes; its more like ringing a bell.
Reply #19November 11, 2011, 08:02:03 am
Luckypabst
  • 502
« Reply #19 on: November 11, 2011, 08:02:03 am »
Sharp blow to the outside of the cam gear works just as well to break the taper free. From my experience, the cam gear is brittle enough that it will chip before mushrooming... not that either one is necessarily a good thing.
Chris
'82 TD Westy
'81 NA Caddy
Reply #20November 11, 2011, 10:07:50 am
gnavs
  • 340
« Reply #20 on: November 11, 2011, 10:07:50 am »
I was scared to hit it with a hammer so I used a gear puller and a blowtorch.  It was a PITA
Reply #21November 11, 2011, 10:13:41 am
maxfax
  • 2126
« Reply #21 on: November 11, 2011, 10:13:41 am »
Reply #22November 11, 2011, 02:02:58 pm
« Reply #22 on: November 11, 2011, 02:02:58 pm »
Less scary than a hammer for sure ;)
Reply #23November 11, 2011, 02:10:45 pm
maxfax
  • 2126
« Reply #23 on: November 11, 2011, 02:10:45 pm »
Pending how hot things were I'd be wary of using that sprocket over.. Maybe even the cam..
Reply #24November 11, 2011, 02:41:03 pm
92EcoDiesel Jetta
« Reply #24 on: November 11, 2011, 02:41:03 pm »
A puller is the wrong tool to use on a tapered fit because it pulls straight out. The force may be tremendous and may weaken the sprocket. A hammer is the right tool and the spot to hit is one of the ribs where it is strongest (with a punch through the hole in the sheet metal). No worry of damaging the sprocket teeth. Hitting the teeth, which is on the biggest o.d, maybe too much of an angle. VW put the hole in the sheet metal (further in diameter wise) so the angle is correct when hit with a punch/hammer.
Reply #25November 11, 2011, 02:43:05 pm
« Reply #25 on: November 11, 2011, 02:43:05 pm »
The whole point is that using a METAL hammer will shock it into popping right off, just hit the back of it at a slight angle so it won't even touch the teeth.
I used to think a rubber hammer was the trick since it wouldn't dent anything.......now I use a metal hammer and every time I wonder why the gear is so loose, I torque the bolt to 45ft-lbs and it pops off really easy.
Reply #26November 14, 2011, 07:59:40 am
regcheeseman
  • 714
« Reply #26 on: November 14, 2011, 07:59:40 am »
variety is the spice of life so another method....
I've damaged a pulley by getting too enthusiastic with a particularly recalcitrant pulley taper so changed tact.
Slacken nut
I use a wide (4in) brick bolster chisel to act as a lever to apply a little force behind the pulley to lever it away from the engine then give the bolt head a sharp tap.
Maybe not ideal?  I'll try the punch through hole technique next time.
Reply #27November 14, 2011, 08:17:51 am
« Reply #27 on: November 14, 2011, 08:17:51 am »
I just do it the way the Bentley manual says to do it... Figure they know what they are talking about.
"Loosen the camshaft drive belt sprocket bolt by 1/2 turn.  Loosen the sprocket from the camshaft by tapping the back side of the sprocket with a drift through the hole in the rear drive belt cover."
Reply #28November 14, 2011, 01:28:07 pm
gnavs
  • 340
« Reply #28 on: November 14, 2011, 01:28:07 pm »
Well now I know  ;D
Reply #29November 14, 2011, 02:32:01 pm
« Reply #29 on: November 14, 2011, 02:32:01 pm »
Well now I know  ;D
Can YOU say Dead Horse??
