Author Topic: Special socket for IDI injection pumps  (Read 8890 times)
October 27, 2011, 08:06:27 am
Henchman
  • 183
« on: October 27, 2011, 08:06:27 am »
Hi,
What is the best source for the triangular socket needed to fully disassemble a Bosch IDI pump?  Also, will this work on the early TDI pumps as well?
Thanks,
Ian
Reply #1October 27, 2011, 09:20:45 am
ffgb
  • 244
Re: Special socket for IDI injection pumps
« Reply #1 on: October 27, 2011, 09:20:45 am »
I had a hard time sourcing out that tool! I ended up making one from a 10mm 6pt socket and a dremel. I can't recall where I saw the specs of the angles where you would need to grind out the material on the socket, but my homemade modified socket works like a charm!
Reply #2October 27, 2011, 11:31:14 am
starrd
  • 128
« Reply #2 on: October 27, 2011, 11:31:14 am »
One of these?
Got to: http://www.metalnerd.com
search in Specialty Bits and Drivers - $23 US
rt MN3001 - Specialty Socket for Triangular Head Bolts
Black 1996 Passat TDI Malone tune, K03/04 Hybrid, Keyless, VR6 Clutch & PP357's
White 1993 Passat TD - GTD nozzles, Keyless - Giles pump, K14, Intercooler, 228mm VR6 clutch & PP, CTN Trans etc
Red 1990 Corrado - custom chip by
Reply #3October 27, 2011, 12:29:45 pm
92EcoDiesel Jetta
« Reply #3 on: October 27, 2011, 12:29:45 pm »
It's 3 sided, equal angles between them. Easy to make with a socket and a grinding bit on a Dremel.
Reply #4October 27, 2011, 01:50:48 pm
Henchman
  • 183
« Reply #4 on: October 27, 2011, 01:50:48 pm »
I saw that earlier, that is why I asked if the TDI and IDI bolts had the same head.  Just checked with metalnerd and they say it won't work.
Prothe has em....
Ian
One of these?
Reply #5October 28, 2011, 01:06:05 pm
jb86
  • 102
« Reply #5 on: October 28, 2011, 01:06:05 pm »
Hans/emiata has it
Cheap
I bought one from him
Jon
Reply #6October 29, 2011, 10:20:09 am
Reply #7October 29, 2011, 07:59:06 pm
  • 4550
« Reply #7 on: October 29, 2011, 07:59:06 pm »
How about this one?
http://www.ecstuning.com/Volkswagen-Golf_I-Convertible-Diesel/Tools/Hand_Tools/ES258694/
Little on the expensive side.  I think I would grind out a snap on for that price.
Reply #8October 30, 2011, 12:37:36 am
« Reply #8 on: October 30, 2011, 12:37:36 am »
How about this one?
thats for holding the water pump by the bolts, to loosen them..
Reply #9November 01, 2011, 07:37:30 am
jb86
  • 102
« Reply #9 on: November 01, 2011, 07:37:30 am »
I agree to be careful what you buy from emiata
But a socket for a few dollars isn't going to leave you stranded somewhere
He has the socket that fits
Only a few bucks
Among the things I've bought from him - the exhaust clamp release tool (at manifold), sells for $45-$90 elsewhere. I paid like $15 from him for an identical one I paid about $75 elsewhere
Now I have 2, making it easier to install
Jon
Reply #10November 04, 2011, 03:07:32 pm
Toby
  • 728
« Reply #10 on: November 04, 2011, 03:07:32 pm »
Jon
Getting them to release is easy. Just use a pry bar from the top and the come off with a big "clang". Its getting them back on that is the trick. I finally made a copy of the factory tool and does it work well. It takes about a minute from picking up the clamp to being done.
