Author Topic: Need help- 1.6TD cooling hose NLA - alternate hose ?  (Read 4225 times)
October 24, 2011, 11:13:45 pm
2strokesmoke
« on: October 24, 2011, 11:13:45 pm »
Hi Guys.
I finishing a 88 Fox wagon build.
It has a 1.6TD from an 85 quantum installed.
I went to the local VW dealer,to replace the old "T" hoses which feed and return from
factory oil cooler- to find out they are NLA discontinued.
Part #'s are : 068 121 053 AG   and 321 121 109 F
One hose goes from water pump to cyl upper hose flange and "T" 's off to oil cooler
other hose goes from water pump to heater pipe ? and "T" 's off to oil cooler.
I have replaced ALL other hoses and would like to find NEW hoses to replace these.
Maybe hoses from a transverse application are close and will fit ?
Seeing as a fox wasn't equipped with a diesel- modification is expected- But something close would be great !
I'm open to your suggestions !
Thanks,Mike
Reply #1October 25, 2011, 07:54:31 am
JerryGTD
  • 89
Re: Need help- 1.6TD cooling hose NLA - alternate hose ?
« Reply #1 on: October 25, 2011, 07:54:31 am »
I got my hoses from the bus depot.
Found one for you here: http://www.busdepot.com/details.jsp?partnumber=068121053AG
1991 Jetta GL ECOdiesel
Reply #2October 25, 2011, 08:51:02 am
rodpaslow
  • 670
« Reply #2 on: October 25, 2011, 08:51:02 am »
Get the front, in your case may be side (not sure which way engine is mounted in fox), coolant fitting from a AAZ.  The small hose that runs to the reservoir comes off of this coolant fitting in MK3 cars.  you can just use a regular hose to the rad and a small hose from the fitting to the reservoir.
I had a aluminum fitting in my 1.6td, I just drilled and tapped it for a 1/4 NPT and have had no problems with it.  I was not going to pay $250 CAD for that hose!
Reply #3October 25, 2011, 10:28:43 pm
2strokesmoke
« Reply #3 on: October 25, 2011, 10:28:43 pm »
Hi Guys,
Thanks for your replies !
I may end up making these hoses as well- Haven't decided yet.
$ 88 for one hose is pretty steep - and it's a VW sub part # (as per VW dealer)
But then agian, the original is 25 years old and not too bad-so if I get another 25 years-might be worth it.
Here is what my hoses look like:
http://i781.photobucket.com/albums/yy93/mowerman101/88%20Fox%20Wagon%201%206TD%20Build/oilcoolerhosespic1.jpg
http://i781.photobucket.com/albums/yy93/mowerman101/88%20Fox%20Wagon%201%206TD%20Build/oilcoolerhosespic2.jpg
http://i781.photobucket.com/albums/yy93/mowerman101/88%20Fox%20Wagon%201%206TD%20Build/oilcoolerhosesonenginepic1.jpg
http://i781.photobucket.com/albums/yy93/mowerman101/88%20Fox%20Wagon%201%206TD%20Build/oilcoolerhosesonenginepic2.jpg
Anyone think of anything else I may be able to use ?
Thanks,Mike
« Last Edit: October 25, 2011, 10:32:36 pm by 2strokesmoke »
Reply #4October 27, 2011, 03:37:00 pm
2strokesmoke
« Reply #4 on: October 27, 2011, 03:37:00 pm »
Hi Guys,
Thanks for all your help and input,with these hoses.
I've decided to fabricate metal "T" fittings,for both of these hoses,
so I can use easy to find non turbo hoses and standard 5/8" heater hose.
My decesion is based on future availability of hoses.
I'm building a daily driver and prefer to use parts that can be easily found,
in the event of a breakdown,ect.
The last thing I want,is to have the car sitting around for weeks,while I try and locate
new hoses.This way,all the parts are easy to aquire.
I have already fabricated a 5/8" 3 way "T" for the oil cooler return hose and
a 1" X 1" X 5/8"  "T" for the bypass hose,to feed the oil cooler ( used a 1" threaded pipe-
3" long and drilled and tapped a hole in the center for 3/8" pipe,where I installed a 3/8"
Pipe X 5/8" hose barb and used JB weld on threads for sealant) Looks like it will do the trick.
Agian,thanks for your input !
Mike
Reply #5November 12, 2011, 08:33:33 am
GEE-BEE
  • 1604
« Reply #5 on: November 12, 2011, 08:33:33 am »
I make all those hoses in silicone
068121053e
037122058
028121053 q
I also make the oil cooler delete hose with no t
037122058-mod
GB
MK1AUTOHAUS stocks just about everything
I did all the MK gas assys also
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #6November 13, 2011, 09:19:48 am
« Reply #6 on: November 13, 2011, 09:19:48 am »
gee-bees stuff rules
Reply #7November 13, 2011, 11:30:35 pm
2strokesmoke
« Reply #7 on: November 13, 2011, 11:30:35 pm »
Hey Gee-Bee,
I did check your ebay store,as I have bought from you before.
Didn't find anything to fit the Quantum 1.6TD or the Fox
The longitudinal setups seem to use different hoses- the oil cooler is clocked differently,due to interference with the D/S engine mount / clutch cable mount.
If you do make these hoses, let me know.
sent you a PM
Thanks,Mike
