Author Topic: Saab oil cooler installation  (Read 4389 times)
September 17, 2011, 01:34:58 pm
« on: September 17, 2011, 01:34:58 pm »
So I picked up a thermostatic sandwich plate, lines and oil cooler off of a saab a couple days ago and last night installed it.
Easy install, perfect bolt on application. Of course you have to find somewhere to mount the cooler as it wasn't made for these cars but the sandwich was easy. Just have to unthread the stock oil filter fitting and use the one that came off of the saab.
I haven't driven lots yet but I used to get pressures (no oil temp gauge) like 40psi cruising at 60mph (2500 rpm) now it was more like 50-55 psi.
I'll update when I go on a longer drive and get more info.
For $20 I was happy ;D.
Reply #1September 21, 2011, 02:58:08 am
damac
  • 531
Re: Saab oil cooler installation
« Reply #1 on: September 21, 2011, 02:58:08 am »
Is this something that is needed for a stock setup 1.6td??
1985 turbo diesel jetta
Reply #2September 21, 2011, 02:07:11 pm
« Reply #2 on: September 21, 2011, 02:07:11 pm »
I don't have a oil temp gauge but I think this is way better than the stock oil cooler.
This cooler is about 6X7x2 inches so it's pretty little, you could use the saab sandwich plate and hoses with a bigger cooler and it would be perfect.
Reply #3September 22, 2011, 11:47:50 pm
damac
  • 531
« Reply #3 on: September 22, 2011, 11:47:50 pm »
What was the reason to install in the first place though?  At some point I assume cooling the oil is not doing the engine good?
I was wondering if it would be good to run something like this on a well running higher mileage engine to baby it?
What year/models can you find that piece on?
Reply #4September 23, 2011, 10:01:49 am
nathan_b
  • 361
« Reply #4 on: September 23, 2011, 10:01:49 am »
that's why it has a thermostat, it can never hurt to have extra oil cooling capacity on tap.
Reply #5September 23, 2011, 06:51:42 pm
« Reply #5 on: September 23, 2011, 06:51:42 pm »
Kinda bugs me but I never thought to see what car it was, I know it had a turbo but I haven't got a clue as to the year. I'm sure I'll go back sometime so I can check then. I wanted a new o-ring for between the filter flange and the sandwich but couldn't look it up for lack of model info ::).
