Author Topic: another hunting/lopey idle topic...  (Read 17402 times)
Reply #30September 20, 2011, 05:22:42 am
carrizog60
  • 978
Re: another hunting/lopey idle topic...
« Reply #30 on: September 20, 2011, 05:22:42 am »
i am in portugal,dont have trafic problems on were i live.
 i have a passat 35i variant 1.9d(1Y),with 1Y custom intake,megane rs front intercooler,vnt2052v turbocharger,tdi gearbox,oil cooler,60mm stainless exhaust,and i am building a 11mm pump.
that is not a "stock" engine,and will(if pump work like i hope) sound bad ass at idle and perform on he road the same way.
Portugal
Reply #31September 20, 2011, 11:10:21 am
« Reply #31 on: September 20, 2011, 11:10:21 am »
its not sleeper status tho.. diesels should all idle like a stock diesel.. that makes your opponent that much more surprised/pissed off when you go smokin by him..
Reply #32September 20, 2011, 01:55:29 pm
carrizog60
  • 978
« Reply #32 on: September 20, 2011, 01:55:29 pm »
I don't have opponents lol
I ride smooth,the idle thing is for self-pleasure ;D
The land rover TDI pump arrived, so the 11mm donor is at home.
The plan is to build the pump the regular way (to be easier to pinpoint problems) and then when all is ok try to adjust the springs strength
« Last Edit: August 03, 2021, 07:59:47 pm by ORCoaster »
Portugal
Reply #33August 03, 2021, 07:50:07 pm
Ebuet
  • 1
« Reply #33 on: August 03, 2021, 07:50:07 pm »
Thicken your fuel till the idle compensation can't happen fast enough :-\
Hello, what do you mean by Thickening the fuel? Make it more viscous?
« Last Edit: August 03, 2021, 08:01:06 pm by ORCoaster »
Reply #34August 03, 2021, 08:02:46 pm
  • 4549
« Reply #34 on: August 03, 2021, 08:02:46 pm »
Adding some diesel fuel additives can increase the thickness of the fluid.  This leads to higher internal pressure and with some additives more Cetane which will add power to the fuel.
