Author Topic: Lots of clatter from 10mm hybrid pump on franken motor  (Read 7987 times)
August 11, 2011, 02:52:22 pm
regcheeseman
  • 714
« on: August 11, 2011, 02:52:22 pm »
I am running a 10mm headed AAZ pump on my franken.
It was set at 1.2 mm but seemed to stumble when asked to rev from idle, and be reluctant to idle clean when cold. It had quite a heavy clatter that may be knock
I retarded it a bit - the stumble got worse as did the idle and the clatter remained.
so now I timed it up so the flywheel has about 10 degrees more advance than the original 1.2mm setting (I can't measure the lift in situ because I need to make a tool up to get the injection sensor out without having to remove the lines.
However the stumble is improved, the idle is good  (engine is warmer by now though) but clatter seems bad.
When I drive the car if I let off the accelerator the clatter is gone, as soon as I start to press the accelerator pedal the clatter is back.
The clatter is heavy at idle but as soon as the throttle is touched it gets a lot louder until the motor is revving hard when it subsides again.
I also let the car sit and tick over and noted that from cold there is some clatter, it disappears nearly totally as the engine warms but as the engine gets hot it's back worse than ever.
Any ideas?
Reply #1August 11, 2011, 03:17:59 pm
rallydiesel
  • 1880
Re: Lots of clatter from 10mm hybrid pump on franken motor
« Reply #1 on: August 11, 2011, 03:17:59 pm »
Maybe the check valves on the rotor? Are the injectors newly balanced and what tips?
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #2August 11, 2011, 03:25:38 pm
Powered by Spearco
  • 1203
« Reply #2 on: August 11, 2011, 03:25:38 pm »
I don't know much of your engine build but I have a 1.6/1.9 Franken motor with a 10mm head on a custom pump from Giles.
I too had a simular noise and condition with the pump timing set the same as yours. Loud clancking, studdering when cold and seemed worse when warmer even throttlred up.
I just backed off timimg when it was running at opperating temp. until the noise subsided. Even during throttling it up. The noise seemed to go away. I thing you had already posted something about your timing before but it worked for me. What injectors are you using? Whats the breaking pressure? Are you using the AAZ injector distributors?
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #3August 11, 2011, 03:32:27 pm
regcheeseman
  • 714
« Reply #3 on: August 11, 2011, 03:32:27 pm »
I have AAZ 155 bar injectors, no problems there as it ran quiet with a stock pump on.
Glad you mention the distributors as they will be the original TDI ones - should that matter? I assumed they were a fairly low pressure one way valve?
Do you mean the same things?  ???
« Last Edit: August 11, 2011, 03:34:05 pm by regcheeseman »
Reply #4August 11, 2011, 03:35:22 pm
Powered by Spearco
  • 1203
« Reply #4 on: August 11, 2011, 03:35:22 pm »
Well, Giles told me that when using the dual spring injectors, I should also be using the delivery ports as well. They are different than the single stage injector.
'13 Golf R:. Tuned
'98 Puch G320
Reply #5August 11, 2011, 05:13:37 pm
regcheeseman
  • 714
« Reply #5 on: August 11, 2011, 05:13:37 pm »
I'll swap them over an post back the results, that fails, I'll refit the 9mm head.
Reply #6August 11, 2011, 06:20:40 pm
rallydiesel
  • 1880
« Reply #6 on: August 11, 2011, 06:20:40 pm »
Yeah same things.
Reply #7August 11, 2011, 06:36:41 pm
Powered by Spearco
  • 1203
« Reply #7 on: August 11, 2011, 06:36:41 pm »
The one thing you might want to take into concideration when changing the delivery valve from the single stage to the dual stage is that there is specific sized shims for the dual type compaired to the single type. Also one thing about the dual type delivery valve spacers is that they need to be all the same size and the pump really should be calibrated to get the best output.
'13 Golf R:. Tuned
'98 Puch G320
Reply #8August 11, 2011, 06:38:51 pm
truckinwagen
  • 1895
« Reply #8 on: August 11, 2011, 06:38:51 pm »
my cummins pump(11mm?) has always clattered really bad when advanced enough to perform properly.
modding the dynamic advance alot helps, but it has always been really loud.
-Owen
83 Opel Kadett Diesel
Reply #9August 11, 2011, 08:16:09 pm
410
  • 581
« Reply #9 on: August 11, 2011, 08:16:09 pm »
Which camplate are you running?  Are you running the camplate that was with the 10mm head or the aaz one?  The tdi camplate has a very aggressive ramp compared to the aaz one but very little difference in overall lift.  I would run the aaz one.  I bet you're on the right track with the delivery valves.  The tdi ones are very different in design.
Reply #10August 12, 2011, 07:56:00 am
regcheeseman
  • 714
« Reply #10 on: August 12, 2011, 07:56:00 am »
I've retarded the pump so it's a little over 1.2mm, and swapped the delivery valves.
It's a little quieter, still the noisiest diesel car engine I've ever heard though.
It has the AAZ camplate already.
The fact that the noise stops completely when lifting off the throttle when driving normally, would that signify it is pump noise? I'm concerned it may be motor related but I think I'm being paranoid.
Reply #11August 12, 2011, 08:18:13 am
  • 4549
« Reply #11 on: August 12, 2011, 08:18:13 am »
I share your motor noise concern.  Does the torque of the pistons change on the crank from one side to the other on a shift from power on to coast on?  Any slack in the bottom on the crank?  Miss a few bolts on torque down?  The only time I had that kind of clack was with a worn out crank shim on a piston arm.  My 2 cents less a penny.
Reply #12August 12, 2011, 08:08:06 pm
410
  • 581
« Reply #12 on: August 12, 2011, 08:08:06 pm »
I remember Libbybapa fighting the exact same issue with a hybrid 10mm pump.  Too much clatter when timing was set for good running and poor running, stumbling when timing was set for less clatter.  I don't recall him coming up with a solution.  I wonder if increasing or decreasing your cracking pressure on the injectors would make a difference.  I'm kind of grasping at straws here.
Reply #13August 13, 2011, 04:53:17 am
Mark(The Miser)UK
  • 1557
« Reply #13 on: August 13, 2011, 04:53:17 am »
How about changing the rate of advance, probably increasing it.
So is that a weaker advance spring, or would a stronger vane pump pressure regulator do it.
Backing off the max fuel might help, but I guess that's not the direction of the GTD forum.
The official setting for the intercooled SB/RA engines was only 0.9, so why are you 1.2 and higher? :o
Mark-The-Miser-UK
Reply #14August 13, 2011, 06:35:09 am
« Reply #14 on: August 13, 2011, 06:35:09 am »
aaz heads drop compression on a 1.6 so u need more advanced timing since the air won't get hot as soon, but apparently running a bigger pump head has an effect on timing some how, i would think it shortens the duration of the injection procress, which would actually advance timing in a way.  but i really don't know dick about injection pumps other than that they have a fly weight governor, a vane pump, and that they advance timing with more internal pressure.
