true or false?
Topic: true or false? (Read 1979 times)
August 07, 2011, 07:28:24 am
ilikevwdiesel
true or false?
August 07, 2011, 07:28:24 am »
On 92 and earlier cars you can use a slow glow relay with fast glow plugs but you can't use a fast glow relay with slow glow plugs.
My Bio
August 07, 2011, 07:38:53 am
Re: true or false?
August 07, 2011, 07:38:53 am »
Assuming the correct glow plugs are used I think your statement is true.
I'm also pretty sure that the Bosch Duraterms are usable with both the slow and fast GP relays.
August 07, 2011, 08:44:35 am
carrizog60
Re: true or false?
August 07, 2011, 08:44:35 am »
match the two but even unmatched i think you can start it also,assuming the engine is in good shape
Portugal
August 07, 2011, 09:09:18 am
Re: true or false?
August 07, 2011, 09:09:18 am »
if you use a slow timer with fast plugs, it will shorten their life..
if you use a fast timer with slow plugs, you glow it twice, and off you go..
August 09, 2011, 07:24:35 am
erice1984
Re: true or false?
August 09, 2011, 07:24:35 am »
fast plugs pull more amps. slow relay on fast plugs will likely burn the relay, and as stated before probably shorten the life of the fast plugs.
fast relay on slow plugs no harm done to either.
1980 Rabbit 1.9TD
true or false?
