Author Topic: 1.6 TD fixins on an AAZ longblock  (Read 2383 times)
July 27, 2011, 12:28:58 pm
ilikevwdiesel
  • 1202
« on: July 27, 2011, 12:28:58 pm »
was wanting to put a T3 on an AAZ...can one just use the 1.6 TD oil pan on the AAZ block and use the T3 oil return without having to do any modifications? guess I was wondering about the oil supply line too any headaches with that?
« Last Edit: July 27, 2011, 12:31:09 pm by ilikevwdiesel »
My Bio
Reply #1July 27, 2011, 12:35:51 pm
Re: 1.6 TD fixins on an AAZ longblock
« Reply #1 on: July 27, 2011, 12:35:51 pm »
the oil drain line is going to be too short.. AAZ is way taller, remember?
Reply #2July 27, 2011, 12:37:01 pm
« Reply #2 on: July 27, 2011, 12:37:01 pm »
You could probably bend the feed line to make it work but the drain will be too short. You'd be better off starting with the AAZ feed line
You also need to do some gentle grinding to the turbo and/or intake manifold to get the T3 to fit, unless I am thinking of a different turbo... ???
Reply #3July 27, 2011, 12:44:42 pm
ilikevwdiesel
  • 1202
« Reply #3 on: July 27, 2011, 12:44:42 pm »
I bought a 92 jetta TD in quebec from this french chick (yes she was hawt!) and it had an AAZ with a k24. it had the 1.6 pan so the drain line had to have been modified? It looked stock to me at the time but that was a few years ago anyways...now I have a mk1 jetta TD with a tired 1.6 and an AAZ eco on the floor in the garage. wanted to blend em but I don't want to get into any fabrication.
My Bio
Reply #4July 27, 2011, 12:48:25 pm
« Reply #4 on: July 27, 2011, 12:48:25 pm »
only 16mm taller so 3/4" might not be a problem. The aaz should drain into the block and you could probaby mate the aaz turbo drain to the t3 and drain it right into the block. shouldn't be too much fab at all and less work than swaping oil pans.
