Author Topic: Dawes valve question  (Read 7117 times)
May 05, 2011, 04:32:39 am
camboscams
  • 324
« on: May 05, 2011, 04:32:39 am »
So where would someone purchase a decently priced one? I can't find one on Mcmaster Carr as i've heard you can find them there.
Thanks Cambo
81' White 1.6l Rabbit 4dr Holseted
72' Ford F-250 390cid
2014 JSW 2.0L TDI Stg 2, CP3 HPFP
Reply #1May 05, 2011, 06:12:08 am
Alcaid
  • 549
Re: Dawes valve question
« Reply #1 on: May 05, 2011, 06:12:08 am »
manual boost controller?
ebay.com and do a search for "nxs boost controller" 20$ + 3$ shipping
'10 VW Passat 1.6TDI Highline
Reply #2May 05, 2011, 12:04:02 pm
Thezorn
  • 381
« Reply #2 on: May 05, 2011, 12:04:02 pm »
Or build your own, http://forums.turbobricks.com/showthread.php?t=59089
Compounded 93 AAZ
Reply #3May 05, 2011, 12:15:03 pm
Reply #4May 06, 2011, 05:34:18 pm
camboscams
  • 324
« Reply #4 on: May 06, 2011, 05:34:18 pm »
Nice link maybe a candidate for the FAQ section!
Reply #5May 07, 2011, 12:43:44 am
Thezorn
  • 381
« Reply #5 on: May 07, 2011, 12:43:44 am »
I built one early last year and have had no problems at all with it.
I think it cost me less then 15 bucks.
Compounded 93 AAZ
Reply #6May 07, 2011, 04:37:20 am
camboscams
  • 324
« Reply #6 on: May 07, 2011, 04:37:20 am »
That's awesome, was the amount of boost pretty easy to adjust and was it very sensitive?
Reply #7May 07, 2011, 10:32:05 am
Thezorn
  • 381
« Reply #7 on: May 07, 2011, 10:32:05 am »
Yea its super nice to adjust (just a bit tricky to get it right the first time), and it hold the boost really steady too. I was running 15lbs of boost with it and it worked perfect.
Compounded 93 AAZ
Reply #8May 07, 2011, 10:35:56 am
« Reply #8 on: May 07, 2011, 10:35:56 am »
mine was the same way, easy to adjust once it was all set up.. kinda a bit tricky when i first put it on tho. you will want to start with it on the lowest setting and work up, i started about in the middle.. wasnt too good of an idea. lol.
Reply #9May 07, 2011, 04:03:40 pm
camboscams
  • 324
« Reply #9 on: May 07, 2011, 04:03:40 pm »
Did anyone ever mount one inside the car? I wonder if you could use it to kinda control mileage, or be a deterrent to keep my foot out of it and get good mileage  8)
Reply #10May 07, 2011, 04:52:44 pm
macka
  • 957
« Reply #10 on: May 07, 2011, 04:52:44 pm »
depends on if the blow off goes into the cabin or not. ;)
Quote from: Vincent Walden
Reply #11May 07, 2011, 09:09:22 pm
DieselBalz
  • 301
« Reply #11 on: May 07, 2011, 09:09:22 pm »
I built mine from an air regulator in the airtools section of Home Depot (came with a gauge, they of course were out of stock of the one without the gauge) and two 1/8to1/4 NPT barbed connector, 1 package of the 3/8 vacuum line tubing, 4 tiny little hose clamps, and plumbers tape. I think all together even with the more expensive valve, 30 bucks.
Works like a champ, and it will hold 20 psi all day long. Once I neaten up the engine bay a little more, the gauge will look cool in there, doing nothing. :D
Reply #12May 08, 2011, 01:50:55 am
Thezorn
  • 381
« Reply #12 on: May 08, 2011, 01:50:55 am »
Haha yea I would definatley start with no spring tension at all :P
I actually hooked mine up to my air compressor and set it to 15 psi to try and dial it in like that, I guess it sorta worked but it still took alot of playing around with to get it set right
Compounded 93 AAZ
Reply #13May 08, 2011, 06:26:35 am
camboscams
  • 324
« Reply #13 on: May 08, 2011, 06:26:35 am »
Yea rather be safe then sorry for sure!
What do you mean about blow off?? Its going on a vnt setup and im not planning on running a blow off valve if that's what your referring to
Reply #14May 08, 2011, 10:47:02 am
« Reply #14 on: May 08, 2011, 10:47:02 am »
a pressure regulator doesnt function the same way a boost controller does.. and usually, dont regulators have like, a 100 psi gauge on them?
