Author Topic: audi 5000 diesel and a k26?  (Read 13521 times)
Reply #30May 03, 2011, 12:39:06 pm
Re: audi 5000 diesel and a k26?
« Reply #30 on: May 03, 2011, 12:39:06 pm »
i thought the K24 on the diesel did pretty good honestly.. mine used to do 20 psi pretty easy..
Reply #31May 03, 2011, 12:49:16 pm
Alcaid
  • 549
« Reply #31 on: May 03, 2011, 12:49:16 pm »
The K24 from 1.6TD is NOT the same as the one from 2.2T....
'10 VW Passat 1.6TDI Highline
Reply #32May 03, 2011, 12:55:28 pm
« Reply #32 on: May 03, 2011, 12:55:28 pm »
you mean 2.0TD?
im aware that 1.6 K24s are WAY DIFFERENT from a 2.0TD K24.. i own a 2.0TD (the whole engine) i know its different physically, dunno about internally tho.. i know the wastegate is in a different spot on the 2.0 unit, and it has a different flange..
Reply #33May 03, 2011, 01:13:42 pm
Alcaid
  • 549
« Reply #33 on: May 03, 2011, 01:13:42 pm »
 I meant what I wrote, the 2.2 petrol turbo inline 5 engines. There are many suggestions in this thread to use the K26 or the K24 from petrol engines, but they are sized completely wrong for a diesel.
Reply #34May 03, 2011, 01:30:41 pm
« Reply #34 on: May 03, 2011, 01:30:41 pm »
the K24 or 26 from a gasser has a HUGE hot side on them. way bigger than any of the diesel turbos.. yea, the gasser units are gonna have alot more lag than the appropriate diesel turbo..
