Author Topic: conversion questions  (Read 3535 times)
April 04, 2011, 05:26:29 pm
ilikevwdiesel
  • 1202
« on: April 04, 2011, 05:26:29 pm »
I have a 95 Golf TD rustout here and a 91 GTi 16v can be had nearby. has anyone ever done a swap like this? mk2 16v gas to diesel using a mk3 for a donor? it's pretty much just a parts change isn't it? gastank exhaust do some wiring? if anyone's done it please let me know what you think.
My Bio
Reply #1April 04, 2011, 05:37:12 pm
jasonsansfleece
  • 162
Re: conversion questions
« Reply #1 on: April 04, 2011, 05:37:12 pm »
I put a mk2 diesel engine into a mk2 gasser Golf
Straight forward.
Give me a call if you like
Reply #2April 04, 2011, 05:44:25 pm
ilikevwdiesel
  • 1202
« Reply #2 on: April 04, 2011, 05:44:25 pm »
oh that's an easy one I'm wondering about the mk3 to mk2.
My Bio
Reply #3April 04, 2011, 06:00:47 pm
rallydiesel
  • 1880
« Reply #3 on: April 04, 2011, 06:00:47 pm »
Well the mounts are the same. I think it would be pretty straight-forward.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #4April 04, 2011, 06:14:50 pm
jasonsansfleece
  • 162
« Reply #4 on: April 04, 2011, 06:14:50 pm »
No need to change the gas tank or the wiring either (if you dont mind a few redundant connectors hanging around)
Reply #5April 04, 2011, 06:17:23 pm
ilikevwdiesel
  • 1202
« Reply #5 on: April 04, 2011, 06:17:23 pm »
I would want to change the gas tank and lines if they fit so I can get rid of the fuel pumps and the restriction on the filler neck. I think they interchange but not positive.
My Bio
Reply #6April 04, 2011, 06:52:51 pm
jasonsansfleece
  • 162
« Reply #6 on: April 04, 2011, 06:52:51 pm »
You could take out the in tank pump if you wanted to. For the filler restriction, I tore out the metal flap and heated up a piece of 1" tube IIRC with a gas torch and enlarged the hole accordingly.
Reply #7April 04, 2011, 07:05:40 pm
ilikevwdiesel
  • 1202
« Reply #7 on: April 04, 2011, 07:05:40 pm »
ok I hear ya man but I don't want to do all that stuff. I just wanna plug and play otherwise it's too much work. you feel me?  8)
My Bio
Reply #8April 04, 2011, 07:21:09 pm
jasonsansfleece
  • 162
« Reply #8 on: April 04, 2011, 07:21:09 pm »
Yes, but swapping tanks is work too! Its easier to mod the filler neck and leave the pump in.
This is Livermore ghetto we are talking, yes ;D
Reply #9April 04, 2011, 07:23:35 pm
ilikevwdiesel
  • 1202
« Reply #9 on: April 04, 2011, 07:23:35 pm »
geto? sheet lol
My Bio
Reply #10April 04, 2011, 09:48:17 pm
shwak23
  • 417
    • Blackdog Junkyard
« Reply #10 on: April 04, 2011, 09:48:17 pm »
Livermore? Ghetto? Who would say such a thing!?  ;D
Reply #11April 04, 2011, 11:11:58 pm
nathan_b
  • 361
« Reply #11 on: April 04, 2011, 11:11:58 pm »
look up ce2, it should be plug and play..
Reply #12April 05, 2011, 03:26:58 am
jasonsansfleece
  • 162
« Reply #12 on: April 05, 2011, 03:26:58 am »
Some snob from the coast! ;D
Reply #13April 05, 2011, 05:32:27 am
BigVWman
  • 332
« Reply #13 on: April 05, 2011, 05:32:27 am »
Heck the engine swap part is easy under the hood and even wiring since its ce2 and a td(not many wires needed to make it work properly)! the gas tank i have no personal exp with but shouldn't be that bad!It just seems like everytime i drop one(tank) from up north i end up breaking bolts and drilling and tapping something.
Tim
83 rabbit shell 92 cabby tdi conversion, 91 cabby aba conversion, 87 cabby,  87 gti,  01nb tdi new project,00 1.8t nb, 98 ranger,92 f150 flareside(its pink) 97 cabrio and a 00 cabrio!
Reply #14April 05, 2011, 07:16:31 am
  • 1739
« Reply #14 on: April 05, 2011, 07:16:31 am »
You won't be able to exchange fuel tanks, but i don't think it'd be too hard to remove the lift pump and run a line down from where it attaches to the bottom of the tank cover. That way you will have the fuel sender  that matches the gauge. The biggest issue would be the exhaust.
