I haven't gotten the metal jacket off, so I doubt it... I can still adjust the idle with the long idle screw on the back of the pump. It barely smokes too.
The man who has an answer for everything. Thanks! I will do that
Quote from: Fredrikkk on April 05, 2011, 12:18:22 amThe man who has an answer for everything. Thanks! I will do that I told you way at the top that you had the fuel screw in too far, do I not have enough posts to be taken seriously yet or something? dang,
yeah that ROR guy is pretty bang on. but does the governor hang? THe "MAX" fuel screw. really, what it does is limit the potential travel of the flyweights in the governor. The more you turn it in, the more they are held back. and when they get held back, the springs connected to your throttle lever win the battle and pull the spill collar further on the spill port, resulting in more fuel.Hence less engine braking, cause after a certain point you never get the sweet, zero injection duration when off throttle at highway speed.
