Author Topic: Going Gas to Diesel/Which Clutch Question??  (Read 1948 times)
April 02, 2011, 07:46:25 pm
ein bora
  • 377
« on: April 02, 2011, 07:46:25 pm »
Starting to collect parts for my 2000 1.8T passat gas to 1.9 idi diesel conversion, and will be using the original 5-speed transmission (other than changing out the fifth gears) for the project. I'd like to install a beefier clutch set up, but I am not sure which clutch kit I need to buy. Do I buy one that's meant for the 1.9 idi, or one to match the original for a 1.8T??
How about the flywheel, which do I use??
Any help appreciated. Thanks.
If you can't take advice - then you can't be helped!
Reply #1April 02, 2011, 08:52:03 pm
Thezorn
  • 381
Re: Going Gas to Diesel/Which Clutch Question??
« Reply #1 on: April 02, 2011, 08:52:03 pm »
So your using the tranny from the 1.8T?
Im not 100% sure on the size of the clutch assembley from the 1.8T but im pretty sure, since its a 5 speed, its 228mm, im sure someone will know for sure.
All VR6 clutches are 228mm (MK3 at least) also so any one of those would work fine. Only thing is, is im not sure if the bolt pattern for the pressure plate to the crank is the same from the VR6's to the 1.9IDI. I do know that the VR6s pressure plates fit on 1.9TDI's though.
In the MK4 generation I think most 5 speed transmision engines have 228mm clutches, besides the 2.0L. They also had the 6 speed transmision which had a 240mm clutch.
Main thing you need to know is if all the engines have the same PP to crank bolt pattern.
Compounded 93 AAZ
Reply #2April 02, 2011, 09:35:51 pm
nathan_b
  • 361
« Reply #2 on: April 02, 2011, 09:35:51 pm »
arent b5 transmissions/engines a unique bell housing pattern?
