Author Topic: Alternators  (Read 6818 times)
Reply #15September 06, 2011, 12:43:20 am
maxfax
  • 2126
Re: Alternators
« Reply #15 on: September 06, 2011, 12:43:20 am »
I can't recall which pin is what off hand, however they are labeled on the regulator....  One is a feed from the stator (or W terminal if you will)..  One is for the volt gauge or charge light (pending on application) third is a power for the regulator..  I forget if it's switched, for some reason I'm thinking it is, but I'll have to check for sure when I get to the shop...  I can post a diagram...
Reply #16September 06, 2011, 12:56:46 pm
Re: Alternators
« Reply #16 on: September 06, 2011, 12:56:46 pm »
How about just a 90a mk2 alt? I need a better alt, and one that preferably has a stud for the charge wire as opposed to the two spades...
While were on that... How do I upgrade that wire on the two spades? Are they headlight size spades?
Reply #17September 06, 2011, 09:40:46 pm
ToddA1
  • 434
Re: Alternators
« Reply #17 on: September 06, 2011, 09:40:46 pm »
As mentioned, I'm using a A2 alternator.
The spades on your alternator are 3/8".  I've run as large as 8ga wires from each, straight to the battery.
-Todd
