Author Topic: Machining squirters in block  (Read 4688 times)
Reply #15April 04, 2011, 08:12:47 am
Re: Machining squirters in block
« Reply #15 on: April 04, 2011, 08:12:47 am »
if you are running around stock fueling an boost pressures (basically factory specs) it hardly seems like theres a need for them..
and the n/a builds ive seen where people throw in squirts, thats less than necessary also..
oil squirters would have saved my engine that one night, maybe.. but i was being a retard.
if you have a good EGT gauge, and you have enough sense to pay attention to it and never get it too hot, you will NEVER need squirts.. its when you have to get the combustion really hot, and keep it there. thats when your pistons start yelling at you to let off, then shortly after, your engine locks up.
basis of post: if your engine doesnt make enough heat to need squirts, its kinda a waste of time IMHO..
again.. just my opinion.
Reply #16April 04, 2011, 07:45:39 pm
monomer
  • 414
« Reply #16 on: April 04, 2011, 07:45:39 pm »
I'm also looking into swaintech coatings....
I'm already far into the build, whats a few hundred more?  ;D
www.michiganvw.org
Reply #17April 04, 2011, 07:46:31 pm
« Reply #17 on: April 04, 2011, 07:46:31 pm »
That is what I said. Look at my build thread sometime if you want to be depressed :D
Reply #18April 07, 2011, 07:34:55 pm
monomer
  • 414
« Reply #18 on: April 07, 2011, 07:34:55 pm »
Block's in the back of the car to goto work with me tomorrow.
Boss ok'd the abuse of the bridgeport, just have to be sure they don't need work on it.
Debating on ordering the 1.8t's and selling this set....
www.michiganvw.org
Reply #19April 07, 2011, 09:10:51 pm
« Reply #19 on: April 07, 2011, 09:10:51 pm »
as simple as machining the boss flat, drilling a hole, and threading it.  ;D
