Author Topic: Machining squirters in block  (Read 4677 times)
March 01, 2011, 09:01:18 pm
monomer
  • 414
« on: March 01, 2011, 09:01:18 pm »
I have an n/a 1.6d block here, have all the squirters.
Is it doable on a bridgeport with no riser?
Next is, how to locate them? have to drill on and able after the hole is drilled and reamed to hit the oil passage?
Just got a proper 2j bridgeport at work. Can hold part to +/- .002 no problems, this should be easy....
www.michiganvw.org
Reply #1March 01, 2011, 09:07:26 pm
clarkrep
  • 117
Re: Machining squirters in block
« Reply #1 on: March 01, 2011, 09:07:26 pm »
I think it's definitely doable but having long enough tooling could be a problem.
Should prolly mill a flat where they seat though too..
Pics would be nice I'm always interested in how others do things and plan to do a couple blocks when I get around to it.
Aaron
'79 Rabbit Diesel L 1.5
'83 Rabbit GTI 1.6TD
Reply #2March 01, 2011, 09:30:36 pm
monomer
  • 414
« Reply #2 on: March 01, 2011, 09:30:36 pm »
Got the long endmills and drills required.
I suppose the hole should be reamed to size?
www.michiganvw.org
Reply #3March 02, 2011, 04:06:27 am
macka
  • 957
« Reply #3 on: March 02, 2011, 04:06:27 am »
yup
Quote from: Vincent Walden
Reply #4March 02, 2011, 08:12:47 am
Quantum TD
  • 1195
« Reply #4 on: March 02, 2011, 08:12:47 am »
Please post pics and any insights you've discovered in the process.
Reply #5March 02, 2011, 10:17:58 am
RustyCaddy
  • 395
« Reply #5 on: March 02, 2011, 10:17:58 am »
This thread has a bunch of info and a DYI:
http://www.vwdiesel.net/forum/index.php?topic=11631.15
Reply #6March 05, 2011, 09:44:39 am
« Reply #6 on: March 05, 2011, 09:44:39 am »
1.8T squirters are MUCH easier to install..they are held in with a banjo bolt.. not a screw.
Reply #7March 05, 2011, 11:52:47 am
Quantum TD
  • 1195
« Reply #7 on: March 05, 2011, 11:52:47 am »
What's the pop pressure on them?
Reply #8March 05, 2011, 12:20:04 pm
« Reply #8 on: March 05, 2011, 12:20:04 pm »
im not positive, but i think its lower than the diesel ones? someone else should know for sure. i remember reading that they are slightly different, but dont remember witch ones had what break pressures.
i may have read this over on the whoretex..
Reply #9March 15, 2011, 10:48:55 pm
monomer
  • 414
« Reply #9 on: March 15, 2011, 10:48:55 pm »
Already have the stock VW one's.
www.michiganvw.org
Reply #10March 17, 2011, 09:49:12 pm
tskm2
  • 34
« Reply #10 on: March 17, 2011, 09:49:12 pm »
update? i'm interesed to, for put squirter in my 2 n/a block
Reply #11March 18, 2011, 02:17:45 pm
« Reply #11 on: March 18, 2011, 02:17:45 pm »
squirters arent even necessary in most situations..
Reply #12April 01, 2011, 05:40:13 pm
monomer
  • 414
« Reply #12 on: April 01, 2011, 05:40:13 pm »
With the money spent on the rest of the build, totaling $2000+ in just parts alone, it's more then welcomed. Stock td's came with them for a reason, and if I'm pushin' 20PSI through a t3.....
Not worth the risk.
Been to busy with work and other projects to do them. I'll be sure to take a bunch of pics.
www.michiganvw.org
Reply #13April 01, 2011, 05:43:41 pm
« Reply #13 on: April 01, 2011, 05:43:41 pm »
Not worth the risk.
i said most applications.. over 20 psi is not one of those applications that they should be omitted..  8)
Reply #14April 03, 2011, 08:14:24 pm
blackdogvan
  • 574
« Reply #14 on: April 03, 2011, 08:14:24 pm »
Care to elaborate??
1991 Vanagon 1.9 mTDI
