Author Topic: 1.9TD project?  (Read 10111 times)
Reply #15December 09, 2010, 03:54:57 pm
Thezorn
  • 381
Re: 1.9TD project?
« Reply #15 on: December 09, 2010, 03:54:57 pm »
NXT Boost Controller is 20$ on Ebay without the ghetto DIY look ;)
You can eliminate the metal line all together by using banjo/barb fittings.
Mine looks more or less the same, I guess that is a bit cleaner but Id say thats pretty ghetto for 20 bucks. Since mine did cost about 10.
and on a side note. The bleeder hole isnt really nessesary unless your running over 20 to 25 psi. Ive ran mine on levels up to 20psi without the hole and it doesnt stutter, it holds even.
« Last Edit: December 09, 2010, 03:57:24 pm by Thezorn »
Compounded 93 AAZ
Reply #16December 10, 2010, 11:08:32 am
Re: 1.9TD project?
« Reply #16 on: December 10, 2010, 11:08:32 am »
the hole works better when you are running lots of boost. i couldnt get my controller to run consistently without the hole, but i was running it at 30 psi..
Reply #17December 10, 2010, 08:39:52 pm
xxkoadyxx
  • 179
Re: 1.9TD project?
« Reply #17 on: December 10, 2010, 08:39:52 pm »
is there such thing as a rebuiild kit for the 1.9td's? wat would i need to do to make a relaible factory spec rebuild? i what it to last another 400k
93 vw Golf 1.9TD soon to be stage 3 malone TDi (project)
2003 VW 1.8T Passat (daily)
Reply #18December 11, 2010, 10:41:16 am
Re: 1.9TD project?
« Reply #18 on: December 11, 2010, 10:41:16 am »
does it not run good? compression low? what calls for the rebuild?
Reply #19December 11, 2010, 02:24:04 pm
rallydiesel
  • 1880
Re: 1.9TD project?
« Reply #19 on: December 11, 2010, 02:24:04 pm »
How is his mbc any more "ghetto" than the ebay one? It's the same thing but at least he built his himself.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #20December 12, 2010, 10:31:33 am
Re: 1.9TD project?
« Reply #20 on: December 12, 2010, 10:31:33 am »
why do you want to rebuild your engine?
Reply #21December 12, 2010, 04:04:01 pm
xxkoadyxx
  • 179
Re: 1.9TD project?
« Reply #21 on: December 12, 2010, 04:04:01 pm »
well its has 330 kms on engine i wanna rebuild.. well kinda rebuild just really the timing belt,bearings,seals,gaskets.. gonna check the compression if i can get alone of the tool..
Reply #22December 12, 2010, 04:07:09 pm
Re: 1.9TD project?
« Reply #22 on: December 12, 2010, 04:07:09 pm »
usually bearings are the last things to fail..
catlin has 430k kms on his engine, still runs great.
really, i wouldnt worry about a full rebuild unless there is something seriously wrong..
Reply #23December 12, 2010, 09:36:13 pm
Re: 1.9TD project?
« Reply #23 on: December 12, 2010, 09:36:13 pm »
I have 310,000 on mine, no issues to speak of other than somewhat higher than normal oil consumption.
"If it ain't broke, don't fix it"
Reply #24December 13, 2010, 01:43:17 am
Alcaid
  • 549
Re: 1.9TD project?
« Reply #24 on: December 13, 2010, 01:43:17 am »
It's smaller and doesn't look like a plumbers parts bin mock-up ;) I'm all for DIY but the ball/spring type boost controllers gives better spool than the bleed-type ones.
'10 VW Passat 1.6TDI Highline
Reply #25December 13, 2010, 04:04:12 am
catlin_cava
  • 1954
Re: 1.9TD project?
« Reply #25 on: December 13, 2010, 04:04:12 am »
Koady, check the compression if its within spec leave it, I've had many AAZ with over 300K on them and drove them hard, pushing over 20PSI all the time and never blew on up.
And like Kevin said, my TDI is over the 430K mark now and running strong.
What you need to do to make nice power is new Headgasket, ARP head studs, a good flowing turbo, and a Giles fuel pump and you'll be able to keep up with me...hell you'll be faster then!
Catlin
2010 VW Golf City 2.0L "Hers"
Reply #26December 13, 2010, 09:22:18 am
Re: 1.9TD project?
« Reply #26 on: December 13, 2010, 09:22:18 am »
yea, cause hes not driving an overweight mk4! lol..
mk2/3 cars are the SHIZZ  ;)
Reply #27December 13, 2010, 09:51:15 am
Alcaid
  • 549
Re: 1.9TD project?
« Reply #27 on: December 13, 2010, 09:51:15 am »
Only beaten by the mk1 ;D
Reply #28December 13, 2010, 10:27:40 am
Re: 1.9TD project?
« Reply #28 on: December 13, 2010, 10:27:40 am »
no.. mk1 cars in stock form, against a mk2 in stock form.. there isnt even a doubt in my mind whats gonna happen. the only way the mk1 is gonna win, is on the drag strip.
mk2 cars have much nicer interior, and are much stiffer cars to begin with. my mk1 feels flimzy, and handles like a CADDY.. and in my eyes, a 1500# car should not handle like a land barge..
Reply #29December 13, 2010, 11:16:34 am
Alcaid
  • 549
Re: 1.9TD project?
« Reply #29 on: December 13, 2010, 11:16:34 am »
power-to-weight ratio my friend ;) Handling needs modifications, totally agree on that one! I've had several mk1, 2, 3 and 4s. Each has their own benefits/downsides.
