Author Topic: homemade 2.5" DP  (Read 9941 times)
Reply #15October 26, 2010, 04:59:22 pm
Re: homemade 2.5" DP
« Reply #15 on: October 26, 2010, 04:59:22 pm »
easiest way to build a downpipe on a mk1 car is to install a VNT on it, then there is only 2 90* bends needed,
Where did you get the flange for the VNT?
made it, crudely torch cut (with an extremely dirty, worn out torch tip) some steel, and then i layed it on my surface grinder to true it up a tad bit. then i use cut up a Mitsubishi G54B exhaust manifold gasket for the turbo gasket, just cut the mitsu gasket into 4 pieces, then you got 4 exhaust gaskets! nothing special, but my downpipe has worked fine for as ling as ive had it on the car. it cracked one time, but then i reinforced it way good.. thought about building a mount to the block for it.
Reply #16October 26, 2010, 07:51:27 pm
dankcorey22
  • 379
    Cummins!
    • Anything that runs
« Reply #16 on: October 26, 2010, 07:51:27 pm »
easiest way to build a downpipe on a mk1 car is to install a VNT on it, then there is only 2 90* bends needed, one directing the exhaust down, and one directing it back..
(lol  8))
Right im gonna trade my K03 turbo and manifold for anyone with a vnt-15! any offers?!  :D PLEASE  :D
MY CARs-BLACK 99.5 Jetta TDI 5 speed 93,000- DC Stage 2 Clutch Kit 14Lb FW, Afe air intake box, 2.5" DP, 11mm IP, 2.5" stright piped, boost gauge, PP764, RC5 (WOW), 3-Bar, McNally EGT/Boost, 17/22, Race Pipe, EGR Cooler Delete, PD lift pump, R32 MAF housing,FMIC
1983 VW Jetta 1.6 turbo fuel mods
Reply #17October 26, 2010, 07:52:48 pm
rallydiesel
  • 1880
« Reply #17 on: October 26, 2010, 07:52:48 pm »
vnt-15's can be had for pretty cheap over on tdiclub.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #18October 27, 2010, 04:45:12 am
« Reply #18 on: October 27, 2010, 04:45:12 am »
my vnt was a VERY good price, FREE!
Reply #19October 27, 2010, 09:26:18 am
dankcorey22
  • 379
    Cummins!
« Reply #19 on: October 27, 2010, 09:26:18 am »
I had a good one off of my tdi but i sold it for 300 to help with the vnt 17/22
Reply #20October 28, 2010, 08:23:03 am
derekp
  • 94
« Reply #20 on: October 28, 2010, 08:23:03 am »
I built a down pipe for my sons 16V ABA turbo conversion project (ok hold on - its relavant)
I bought mandrel bends for that from
http://www.mandrel-bends.com
They have a lot on their website and also were very helpful on the phone
They have silicon connectors and elbows too.
And I find their prices to be reasonable
The problems I encountered there were fitting things so they wouldnt interfere with the shift linkage
The fleet
92 eco diesel (my driver turned project)
94 suburban (mine)
69 Chevelle 327 w/hillborn - resting nicely
89 Jetta coupe (sons 16v ABA head swap w/turbo and megasquirt - not run yet)
2000 jetta (other sons)
98 jetta (daughters)
2001 jetta tdi (girlfriends)
03 subaru outback (girlfrie
Reply #21October 28, 2010, 10:00:52 am
« Reply #21 on: October 28, 2010, 10:00:52 am »
too bad you didnt keep it for the jetta, would have been the turbo to have, or just take the 17/22 off your TDi! lol...
Reply #22October 28, 2010, 10:47:08 am
rumbling_caddy
  • 80
« Reply #22 on: October 28, 2010, 10:47:08 am »
  Here's my cheapy 2.5" exhaust.  I took an original Mk1 exhaust piece belown the toilet bowl flange local NAPA muffler guy to use as a template.
He cut off the flange and mad this piece for me:
This is before the flange was fully welded.
Then I just pieced together the rest of the exhaust with off-the-shelf slip on 2.5" pipes and ran two mufflers in series.  One cheap muffler and a Borla is got off CL.  Spent a total of about $170.
[/IMG]http://farm5.static.flickr.com/4085/5008011955_9ba99b99cd_z.jpg[/IMG]
Is it a bad idea to keep the stock 1.6TD cast iron downpipe with the toilet bowl flange? It didn't seem to be restrictive to me and of course it's sturdy.
Reply #23October 28, 2010, 03:39:20 pm
dankcorey22
  • 379
    Cummins!
« Reply #23 on: October 28, 2010, 03:39:20 pm »
Haha! i sold that turbo before i got my TD. Or else i would have keep it! i dont know how/where i would run the vacuum hose for the VNT actuator
plus im not trying to make my TD a racer  :P I already have a car for that "TDI"  ;) lol
Reply #24October 28, 2010, 08:06:07 pm
AudiVWguy
« Reply #24 on: October 28, 2010, 08:06:07 pm »
Don't limit your thinking to 2.5 inch, when it comes to getting rid of diesel exhaust, bigger is better. I was able to fit a 3 inch off the turbo. Faster spool-up and lower EGT's .
Cheers,
-JB
Reply #25October 29, 2010, 09:26:35 am
« Reply #25 on: October 29, 2010, 09:26:35 am »
i never hooked up the vain control.. most people used linkages hooked to the injection pump throttle lever.. even with no vain control, it still spooled like a MOFO..
Reply #26October 29, 2010, 03:01:54 pm
dennis
  • 311
« Reply #26 on: October 29, 2010, 03:01:54 pm »
YOu can find a lot of decent mandrell bends at most exhaust shops. A lot of cutting and welding, and putting it on and taking it off. I think Im just gonna buy one next time.
1980 Caddy TD (Always in progress)
1983 Volvo 245 D24 NA Building D24T
1980 Air-cooled Westy
1956 F100 (What to do???))
