Would you run it/ would just a hone fix it.
Topic: Would you run it/ would just a hone fix it. (Read 2247 times)
October 05, 2010, 04:07:14 pm
dash cunning
User+
October 05, 2010, 04:07:14 pm »
So after a botched rebuild i'm left with a spare bottom end that i have sitting around. it ran when i pulled it just blew alot of smoke and was low on power. I was thinking rings but it wasn't blowing by too much oil and it would start up no problem run a second and then smoke hot or cold. When i pulled the head there was oil in the 1 and 4 cylinders. I'm using arp headstuds but how many of you guys would run this bottom end with just a lil cleanup of carbon at the piston line? I messed up 2 pistons and i'm left with little money after my first build so i was hoping i could just re-ring this block, polish the crank, new bearings and be on my way. What do you think?
These are the 2 worst cylinders
4 cylinder
1 cylinder
79' rabbit 1.5 n/a, 89 golf gasser, 91 jetta gasser, 72 westy.
October 05, 2010, 11:15:40 pm
dash cunning
User+
Re: Would you run it/ would just a hone fix it.
October 05, 2010, 11:15:40 pm »
bore it is!! lol
October 06, 2010, 11:28:44 am
October 06, 2010, 11:28:44 am »
are those scores in the first cylinder? or just carbon tracks?
if its scored, that bore is trashed..
October 06, 2010, 03:38:29 pm
October 06, 2010, 03:38:29 pm »
Looks like #1 lost quite a bit of mass...
October 06, 2010, 04:50:35 pm
dash cunning
User+
October 06, 2010, 04:50:35 pm »
all the stuff is at the machine shop but it's looking like i'll have to buy another set of oversized pistons which would be no good. Also does anyone have a source for the glyco bearings and seperate thrust washers, i haven't been able to get ahold of myke_w.
