Author Topic: Head bolt spacers...Three ?!?  (Read 4681 times)
Reply #15October 06, 2010, 11:26:43 am
Re: Head bolt spacers...Three ?!?
« Reply #15 on: October 06, 2010, 11:26:43 am »
why would there only be 3 washers on ONE bolt then? not all 10? your theory would make sense if each bolt had 3 washers..
Reply #16October 06, 2010, 03:43:11 pm
« Reply #16 on: October 06, 2010, 03:43:11 pm »
Actually, because valves are not flush with the head, but slightly sunk, skimming head brings valves closer to piston at TDC.  This raises the compression slightly, [[not neccessarilya bad thing] but also increases the likelyhood of valve clash. I have recently reringed an overskimmed head that used to have a 2 nothch gasket. Valve clash means that I had to use a3 notch, [or actuallly a 5 notch 1.5] to gain a few thou gap . The only downside, is that I've gone from 45mpg to 55 to 65mpg ;D...
[/quote]
Uh, you are supposed to cut the valve seats  at the same time.
Reply #17October 07, 2010, 04:14:04 pm
RustyToy
  • 51
« Reply #17 on: October 07, 2010, 04:14:04 pm »
Exactly how do I determine whether it is an 11mm or 12mm head?
i ask because I am about to tear it back apart.
The diesel fleet:
Smaug - '86 F-250 4x4 6.9L with Banks turbo
Nameless -1965 GMC PD4106 with DD 8v71,4sp
Friggenbroken - '85 VW Golf,1.6IDI,5sp
Friggenslow - '90 Wolfsburg Jetta
1984 VW Rabbit 1.6NA,4sp
The Ton - '79 Chevy CC/dually 'camper special' 6.2L transplant
Reply #18October 07, 2010, 04:18:22 pm
« Reply #18 on: October 07, 2010, 04:18:22 pm »
The head bolts are either 11mm or 12mm...
Reply #19October 07, 2010, 06:09:50 pm
RustyToy
  • 51
« Reply #19 on: October 07, 2010, 06:09:50 pm »
That aint gonna work. the block is a 12mm block, judging by the 12mm bolts that came out of it.
an earlier post in this thread made reference to a 'modified 11mm head' needing those additional spacers on the bolts to keep th bolts from bottoming out.
I need to know whether there is any other way to determine what it is so I know whether those spacers are going to be required when putting it back together.
Another related question: If I were to replace the bolts with studs, am I going to need those spacers?
The diesel fleet:
Reply #20October 07, 2010, 06:49:39 pm
« Reply #20 on: October 07, 2010, 06:49:39 pm »
Ok lets see if I can be a little clearer for you.
Are you using a different head than you removed?
Yes it's different; then see if the 12mm bolts go through the holes, if they do its a 12mm head if not its a 11mm head.
No its the same head; than its a 12mm head as 12mm bolts will not fit in a 11mm head..
Hows that? Clear?
Chances of you having a modified 11mm head are SA-LIM...
Now for another point, There is no reason for there to be "extra" washers on the bolt if they are the correct head bolts.
Reply #21October 07, 2010, 07:09:50 pm
RustyToy
  • 51
« Reply #21 on: October 07, 2010, 07:09:50 pm »
Now that is an answer I can use!
In fact, if memory serves, that answers the question that i opened this thread with.
Thanks!
The diesel fleet:
