Author Topic: replace 1.6 with 1.6 turbo in 82 pickup  (Read 2385 times)
September 05, 2010, 09:51:03 pm
zzyzx
  • 12
« on: September 05, 2010, 09:51:03 pm »
Am looking to replace my 1.6 diesel with a 1.6 turbo diesel in my 82 VW pickup truck. What will I need to do that is different? I read I may need to do something with the motor mount since the engine I am looking at came from Germany. Will the current 1.6 motor mount I have still work or am I going on a parts hunt?
Anything else I need to look at? A new or larger radiator? Any kind of wiring changes?
I like the idea of a bit more power but am I buying more problems in the bargain? Different clutch or pressure plate or even transmission problems as a result?
Reply #1September 06, 2010, 08:10:28 am
GEE-BEE
  • 1604
Re: replace 1.6 with 1.6 turbo in 82 pickup
« Reply #1 on: September 06, 2010, 08:10:28 am »
If the Motor is from a MK1 It will drop in, if from another just switch your mounts
Keep the original coolant flange from the old motor ( sensors)if different
Install new belts and hoses , water pump and belt to be safe...
radiator : you can go to the a/c size of 575 mm, i
Or go to the 675 mm 1991 1.6TD model
I have the list of parts:
two hoses
radiator
two brackets
You can use your MK1 fan support ( with either one ) 575 or 675
GB
« Last Edit: September 06, 2010, 08:13:39 am by GEE-BEE »
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #2September 07, 2010, 08:39:46 am
zzyzx
  • 12
« Reply #2 on: September 07, 2010, 08:39:46 am »
What I am looking at are the engines brought into the US from Germany by the California company. They sell a lot of them.
Am looking at two options. The 1.6 turbo or the 1.6 naturally aspirated with hydraulic lifters. The turbo costs more.
Is the Turbo that much better for an 82 Caddy than the regular engine?
Another possibility is the 1.9 engine without a turbo. But I have been told parts are hard to come by if I need anything. So, based on that I am not looking to hard at it.
Will the turbo really be worth it?
Reply #3September 07, 2010, 09:31:55 am
GEE-BEE
  • 1604
« Reply #3 on: September 07, 2010, 09:31:55 am »
get the 1.9 AAZ , non egr model if you can
parts are easy to find
I will help with your install....
I went from gas to diesel , yours is easier
Who is the importer ?
GB
Switch the coolant flanges from the 1.6 and the engine mounts from the 1.6
Purchase a downpipe and a complete 2.25 or 2.50 exhaust
I have a K&N RX4860 airfilter assy that will match up to the air filter snorkel
Done
« Last Edit: September 07, 2010, 09:33:33 am by GEE-BEE »
Giles Pump OHC
MK1 JETTA DASH
