Author Topic: IP id?  (Read 2512 times)
August 14, 2010, 11:45:54 am
morgoon
  • 60
IP id?
« on: August 14, 2010, 11:45:54 am »
I had some questions regarding the differences in these two IP's
1981 Rabbit
This one is of my early 1.6, at least that is what I think it is
It was mentioned in my intro post back in April, that someone thought it was an early 1.6
with these numbers
This pump is on 1.5 I hope to put in place of the ailing 1.6
with these numbers
These pumps look so similar, are they interchangeable..
As it must be obvious to everyone else, these two pumps are different than the pump on a worn out 1.6 I bought to tear down and learn on
You can just make out the can under the ip in the first photo, it leaks a bit but it runs
The other one hasn't seen a drop of diesel in 17 years
I would like to send the 1.5 pump to Giles, but I wondered if I could get buy with a reseal on the (top photo) pump
I have little experience with this stuff, so any help is much appreciated
Reply #1August 14, 2010, 11:52:23 am
84tdrabbit
Re: IP id?
« Reply #1 on: August 14, 2010, 11:52:23 am »
look at the numbers, they are the SAME PUMP..
did you need to start a thread about that? the numbers are plain and bold. same pump.. part numbers are the same.
next time, just look at the part numbers..
Reply #2August 14, 2010, 12:15:23 pm
Re: IP id?
« Reply #2 on: August 14, 2010, 12:15:23 pm »
Deleted your account again Kevin aka Rabbit on Roids.... we have zero tolerance for your disrespectful posts, as has been explained to you many many many times.
« Last Edit: August 14, 2010, 12:19:55 pm by Vincent Waldon »
Reply #3August 15, 2010, 10:27:07 pm
Baron VonZeppelin
Re: IP id?
« Reply #3 on: August 15, 2010, 10:27:07 pm »
068 130 107 A
Shows to be 77-80 1.5 with manual tranny.
Since both have same number, they both are that same application.
If its running satisfactorly enough on the 1.6, i'd go with it.
i don't know what all would be difrnt on the inside of 1.5 vs. 1.6 pumps - just guessing maybe slightly lower overall fueling.
Perhaps read up on the DIY's of resealing - and do a trial run (dry run without new gaskets) on the pump that has been sitting 17 years before tackling the running pump.
A guy on eBay sells Bosch NA pump rebuild kits WITH the front seal included for $20. You could send him the numbers from your pump to double check if his kit will be suitable.
http://cgi.ebay.com/ebaymotors/VW-Diesel-Bosch-VE-Injector-Pump-Rebuild-Kit-Injection-/250664333516?cmd=ViewItem&pt=Motors_Car_Truck_Parts_Accessories&hash=item3a5cc230cc
This listing has ended, but you can click on view other items, etc...
Several on here have purchased from him.
Reply #4August 16, 2010, 09:03:01 am
morgoon
  • 60
Re: IP id?
« Reply #4 on: August 16, 2010, 09:03:01 am »
Thanks that was very helpfull
Reply #5August 16, 2010, 11:34:07 am
rs899
  • 647
Re: IP id?
« Reply #5 on: August 16, 2010, 11:34:07 am »
I got that seal kit and its a very good deal, but the guy won't answer any questions.
FWIW I had 2 pumps apart this weekend, one had castings dated 1977 ( I assume 1.5 ) and one 1980 ( I assume 1.6).  The only difference I could SEE was the one corner of the front mount (triangle) was slightly different on the '77 , the governor had some see-though holes and the governor spring was slightly different.  I don't know about any internal (valving) differences but there might be some.  Actually, come to think of it , I had to use the cam plate from the '77 in the '80, and IIRC (now) the lift ( timing) spec is different.  Too bad I didn't think to compare them..  oh wellllll.......
Reply #6August 16, 2010, 05:07:46 pm
GTD_MK2
  • 21
    Smoke...
Re: IP id?
« Reply #6 on: August 16, 2010, 05:07:46 pm »
One of the differences of a 1.5 to a 1.6 pump is the governor spring, the 1.5 has got a stiffer spring for a higher rpm limit
A Diesel has to smoke !
1991 Golf Mk2 GTD,(ex EcoDiesel)
Engine 1V, KKK K24, 2.5" DP, 2.5" Exhaust, GTD intercooler, GTD Nozzles, GTD pump ,10mm Plunger, 30Psi boost, AAZ head gasket, Head P&P, 12.9 grade head bolts
