Author Topic: interest: 34/30 steel head  (Read 44128 times)
Reply #15July 12, 2010, 06:32:05 am
NintendoKD
  • 931
    dnahtasinoivilboeraweb
    • myspace page
Re: interest: 34/30 steel head
« Reply #15 on: July 12, 2010, 06:32:05 am »
already contacted them, they politely told me that they didn't want our buisness, in just a few more words
Reply #16July 13, 2010, 06:50:11 pm
smoken u
  • 231
« Reply #16 on: July 13, 2010, 06:50:11 pm »
haha yeah id have to agree maybe just a bit of a mild port job would be about the only change
1990 VW jetta 1.6 td, 2.5" exhaust, no muffler, governor mod 2010 edition, K&N filter. and now 66 hp and 136 ftlbs.
project 1.6 liter in the works  :)
You don't rev a VW diesel, you increase the clatter.
Reply #17July 14, 2010, 11:38:26 am
rodpaslow
  • 670
« Reply #17 on: July 14, 2010, 11:38:26 am »
I'd be interested in one if it ended up in the $500 range.   I'm looking forward to seeing if you can hit the $500 -$800 range as I used to work in manufacturing engineering for a casting steel company in Canada and currently work for a top end, machine shop that does lots for heavy industry.  The other question is I would have is casting/foundries tend to have a large amount of scrap(bad castings) on something complicated like this.  Will there be a warranty if there are problems with the casting?  Or will that be for us to deal with?  Will this be a weldable alloy?  If its .30% carbon or higher that is extremely difficult.  If you can answer a few of those questions - count me in!
Reply #18July 14, 2010, 11:49:56 am
NintendoKD
  • 931
    • myspace page
« Reply #18 on: July 14, 2010, 11:49:56 am »
that is why I made this post, we can add collective design Ideas to make this as best a concept as possible to avoid problems in the final product.  not sure about a warranty, but I will make sure that I will ask, they will be pressure tested and stress tested before they go out to everyone.
Reply #19July 14, 2010, 01:26:31 pm
  • 3468
    • McScrubbins Body Wash
« Reply #19 on: July 14, 2010, 01:26:31 pm »
If anyone has seen Aki-76's head (or is it TurboJ?) I think that would be an avenue to go down. He ported his aaz head to the point where he needed over sized valves. His two valves (per cylinder) almost touch each other.
once we get drawings of the head and a 3D graphical of it, it should be clear how much bigger the points can get before risking structural integrity (seeing as it will be steel not soft alluminium)
Edit: at least i thought they got over sized valves. I couldn't find the pictures in the jetta 200 thread... there is a picture of a piston with big cutouts for larger lift on the valves...
« Last Edit: July 14, 2010, 01:37:15 pm by Smokey Eddy »
Reply #20July 14, 2010, 05:06:37 pm
NintendoKD
  • 931
    • myspace page
« Reply #20 on: July 14, 2010, 05:06:37 pm »
thermal expansion, the mold would have to be redone, couldn't use the same one.  XXX,XXX cost
Reply #21August 24, 2010, 10:59:22 am
gnavs
  • 340
« Reply #21 on: August 24, 2010, 10:59:22 am »
so what's new here?  Don't let this idea be dead in the water...
Reply #22August 24, 2010, 12:50:25 pm
  • 3468
« Reply #22 on: August 24, 2010, 12:50:25 pm »
Well Andy2 apparently has a cast iron head on a TDI... i just read that. Where did he find that?
I'd be very interested in casting an alluminum 16v IDI head. possibly much cheaper? but less potential i suppose.
Reply #23August 24, 2010, 05:53:53 pm
tSoG-84bit
  • 188
« Reply #23 on: August 24, 2010, 05:53:53 pm »
benefits?
wouldn't crossflow be awkward with our IPs kinda in the way?
I'm not sure how I'll get the money, but I'd be interested, but want more info first.
84bit 1.6na
Engine died, pulling it apart, putting something new in it's place.
Reply #24August 24, 2010, 10:20:27 pm
Aki-76
« Reply #24 on: August 24, 2010, 10:20:27 pm »
best valve size is 39 in and 34 ex orginal aaz head.Bigger bore ( 81 ) can use 41 / 35 valves.That latesīt version my own head is allmost twice better flow vs. orginal.
If you can,i recomend rise intake port and use diffrend port shape.
If i make head,can you copy that to cast iron ?
here is flowchart
http://s434.photobucket.com/albums/qq68/Aki-76/asiakas%20osia%20ja%20muuta/?action=view&current=tsivirtauslappu.jpg
http://i434.photobucket.com/albums/qq68/Aki-76/moottorin%20osia/03042010812.jpg
http://i434.photobucket.com/albums/qq68/Aki-76/moottorin%20osia/07102009606.jpg
4 valves per cylinder,that is what we want.
« Last Edit: August 24, 2010, 10:22:56 pm by Aki-76 »
Reply #25August 25, 2010, 10:44:20 am
  • 3468
« Reply #25 on: August 25, 2010, 10:44:20 am »
aki, do you have a video with good sound quality of what that engine sounds like with those massive valves?
Reply #26August 25, 2010, 11:20:09 am
Aki-76
Reply #27August 25, 2010, 12:01:27 pm
honda_is_the_best
  • 104
« Reply #27 on: August 25, 2010, 12:01:27 pm »
not like that thing has torque or anything  8)
thats pretty amazing. love the way it sounds. that squeal is the tires breaking loose in like 3rd gear, right?
thats some pretty amazing stuff Aki, keep up the AWESOME work.
VW it aint just a car, its a way of life..... Boost, Soot, Repeat
Reply #28August 25, 2010, 12:51:05 pm
gnavs
  • 340
« Reply #28 on: August 25, 2010, 12:51:05 pm »
I love the pics of that head, any more?  That's one hell of a port job!
Reply #29August 25, 2010, 02:32:52 pm
rallydiesel
  • 1880
« Reply #29 on: August 25, 2010, 02:32:52 pm »
Did you need to find larger diameter valve seats or did the stock ones have enough material left? Specifically for the 39/34 valves.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
