Author Topic: Engine vibration  (Read 1798 times)
June 15, 2010, 08:55:29 am
rodpaslow
  • 670
Engine vibration
« on: June 15, 2010, 08:55:29 am »
I have my 96 1.6td conversion just about complete and I was attaching my oil cooler and noticed the steel the front mount is attached to is not all that strong, basically 12 ga formed.  I am curious if anyone has welded/bolted a strengthener to see if that would reduce the vibration.  I know my old 90 mk2 1.6na (stock) at idle vibrates noticably.
Reply #1June 15, 2010, 10:06:44 am
Re: Engine vibration
« Reply #1 on: June 15, 2010, 10:06:44 am »
If you strengthen the mount it will transmit more vibrations from engine to body, as less soft material will be there to take up the movement.
These engines just shake a lot, lol
