Author Topic: MK1 1.6 TD INTAKE SNORKEL ( BOOT ) Silicone New Production  (Read 5363 times)
June 06, 2010, 09:13:48 am
GEE-BEE
  • 1604
« on: June 06, 2010, 09:13:48 am »
It's in production
Replaces V.W. # 068-129-067 A ( no longer available )
It will have 48 mm for the turbo side so it will fit all models, the aircleaner side intake will be oblong
( not Round)
I will include two 100% s/s worm gear lined silicone clamp's
Color: Black
Custom Color will be available
Two intake ports like the 1.6TD original model, one can be plugged for the 1.9 AAZ Motor
GB
P.S. Iam doing this as the stock vw model is too big I.D. for the K03 Turbo, the new size will fit all model's and I matched the airfilter intake( oblong) instead of the stock round for a better fit.
« Last Edit: June 06, 2010, 09:32:40 am by GEE-BEE »
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #1June 06, 2010, 09:51:36 am
Re: MK1 1.6 TD INTAKE SNORKEL ( BOOT ) Silicone New Production
« Reply #1 on: June 06, 2010, 09:51:36 am »
YES...
Now how much is this? I really almost bought something from the parts store for a cone filter, but I be this will work better:D
Reply #2June 06, 2010, 10:32:25 am
GEE-BEE
  • 1604
« Reply #2 on: June 06, 2010, 10:32:25 am »
Est 87.50
Did you get your parts ?
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #3June 06, 2010, 07:29:00 pm
sawedoffgolf
  • 213
« Reply #3 on: June 06, 2010, 07:29:00 pm »
Buddy of mine might be interested in 2, for a AAZ would you supply a plug for the extra hole in the tube?
Curious of who is producing these for you, i have been looking around at getting some complete silicone intercooler pipes and turbo inlet pipe for our mk4 tdi's
Reply #4June 06, 2010, 07:43:56 pm
« Reply #4 on: June 06, 2010, 07:43:56 pm »
87 too much for me :(
* MKI - I was thinking MKII my bad *
I got the stuff, but didn't open it. I left it in the wife's jeep too. I need to go get it and fit it up and see if it needs welded just like the one in the FAQ post.
« Last Edit: June 07, 2010, 05:12:57 am by theman53 »
Reply #5June 06, 2010, 09:40:55 pm
GEE-BEE
  • 1604
« Reply #5 on: June 06, 2010, 09:40:55 pm »
Any alloy plug or ( AN 806 )  will work
I have 15 coming out of production...
1- blue
1-red for me
13 black
They will be going to MK1 parts dealer...
1.9 AAZ engine hoses ( 3 ) 1 piece design silicone will be done Monday
If no else makes it or it is NLA from V.W.
Gee-Bee will get it done.....
« Last Edit: June 06, 2010, 09:50:42 pm by GEE-BEE »
Giles Pump OHC
MK1 JETTA DASH
Reply #6June 06, 2010, 11:57:32 pm
macka
  • 957
« Reply #6 on: June 06, 2010, 11:57:32 pm »
He does
Quote from: Vincent Walden
Reply #7June 15, 2010, 12:31:42 pm
GEE-BEE
  • 1604
« Reply #7 on: June 15, 2010, 12:31:42 pm »
This will be available in either size , KO3 TURBO 1.85 O.D.  OR larger T2/T3/K14 2.33 O.D.
let me know ?
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #8June 16, 2010, 06:17:33 pm
« Reply #8 on: June 16, 2010, 06:17:33 pm »
could we see a pic of this? After further inspection, this isn't that bad of a price if it is all I need. I can make it work for an MKII I bet.
Reply #9June 16, 2010, 09:07:26 pm
Baron VonZeppelin
« Reply #9 on: June 16, 2010, 09:07:26 pm »
You can buy used Mk2 snorkels pretty easily - compared to Mk1.
They go cheaper too.
You might can even still get Mk2 new. But probly $100+.
Not trying to jinx a sale for GB, but the Mk1 tube will put you short - unless you're just going with a cone filter. But probly still will be shorter than where you want a cone to be.
2cents
Reply #10June 16, 2010, 10:37:50 pm
GEE-BEE
  • 1604
« Reply #10 on: June 16, 2010, 10:37:50 pm »
It was made to be used for the MK1  stock airfilter ( box) assy
With the new mandrell tool it can be made for either Turbo inlet
KO3 Model (1 in production) Mine
T2/T3/K14 ( 13 in production )
These will be available from MKI Autohaus , he will be the stocking dealer and has a signed agreement.
The MkII snorkel will be next in line for tooling.....
You can always use a AAZ model , Does anyone know if they made different snorkel's( Part # 's ) for the two different Turbo's
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #11July 17, 2010, 07:04:17 am
« Reply #11 on: July 17, 2010, 07:04:17 am »
Reply #12July 17, 2010, 04:30:46 pm
GEE-BEE
  • 1604
« Reply #12 on: July 17, 2010, 04:30:46 pm »
I fit like a glove on my KO3, I re-used the l  bracket from K&N to secure the MK TD airbox
The 1.6 Breather hose fit perfect also to the snorkel, I used a rubber thread protector to cap off the other breather hose ( AAZ )has only one.
This all started with me wanting a MK1  TD airfilter assy , and the the intake for the turbo was too large for the KO3.
I made the mandrell with two different insert's so the i.d. could be made for the T2/T3/K14 Model also
The MK II prototype is in the works , just finsished the Tiico Vanagon project and the made all new silicone assy's for obsolete coolant hoses for Van-Cafe....
What's next ?
Gee-Bee
Giles Pump OHC
MK1 JETTA DASH
Reply #13July 17, 2010, 08:02:08 pm
« Reply #13 on: July 17, 2010, 08:02:08 pm »
Reply #14July 17, 2010, 08:52:47 pm
Baron VonZeppelin
« Reply #14 on: July 17, 2010, 08:52:47 pm »
Great Job on those Snorkels !
