Author Topic: Techtonics tuning downpipes for a mk1  (Read 3605 times)
May 12, 2010, 04:26:55 am
Hiho
  • 77
« on: May 12, 2010, 04:26:55 am »
Has anyone used the techtonics tunings downpipes? I am considering one for my mk1 TD build (part no. 251224)
http://techtonicstuninginc.com/main/index.php?main_page=product_info&cPath=2_11_4_284&products_id=592
The motor will be squeezed for some extra performance and will run a k14 and intercooler. I have asked TT if this downpipe suits the k14 but no answer.....
1978 1.5 GLD
1978 1.6D soon to be TD
Reply #1May 12, 2010, 04:29:42 am
Hiho
  • 77
Re: Techtonics tuning downpipes for a mk1
« Reply #1 on: May 12, 2010, 04:29:42 am »
I just noticed they have a 2.5" downpipe to suit the AAZ motor in a mk1 (part no. 251 224L). As my turbo is off an AAZ motor, the flanges should match. How much taller is the 1.9AAZ over the 1.6?
http://techtonicstuninginc.com/main/index.php?main_page=product_info&cPath=2_11_4_284&products_id=594
« Last Edit: May 12, 2010, 04:33:48 am by Hiho »
1978 1.5 GLD
Reply #2May 12, 2010, 05:13:37 am
« Reply #2 on: May 12, 2010, 05:13:37 am »
I have heard that the AAZ is 16mm taller.
Reply #3May 12, 2010, 06:34:51 am
GEE-BEE
  • 1604
« Reply #3 on: May 12, 2010, 06:34:51 am »
TT downpipes are made for two aaz turbo model's
KO3
T2/T3/K14
I sent them manifolds and turbo so they would have the correct patterns
I have a K03/k04 1..9 AAZ with S/S 2.5 and 2.5 exhaust
Perfect fitment
I drilled and tapped my exhaust manifold  before I had it ceramic coated ( 50.00 )
I also did the tailpipe since I wanted that assy black
Wants pic's
reply to [email protected]
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #4May 12, 2010, 08:57:40 am
« Reply #4 on: May 12, 2010, 08:57:40 am »
Will that 2.5" downpipe fit a Mk II / Mk III?
Reply #5May 12, 2010, 09:50:51 am
« Reply #5 on: May 12, 2010, 09:50:51 am »
a mk1 d/p will only fit an mk1. on mk2/3 cars, a mk1 header/downpipe hits the rack and pinion. and im not talking a little bit either. you cant just dent it a little bit and get it to work. why not buy the specific piece that bolts onto your car? or build your own d/p?
Reply #6May 12, 2010, 06:03:19 pm
Hiho
  • 77
« Reply #6 on: May 12, 2010, 06:03:19 pm »
So if i get the 2.5" AAZ in a Mk1 downpipe it should fit my k14 but dangle an extra 16mm lower?
How about the quality and design - any comments?
Cheers
1978 1.5 GLD
Reply #7May 12, 2010, 06:44:38 pm
GEE-BEE
  • 1604
« Reply #7 on: May 12, 2010, 06:44:38 pm »
Perfect fitment, Iam sure you can make the rest of the 2.5 exhaust system...
Enjoy the pic's
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #8May 12, 2010, 11:42:41 pm
« Reply #8 on: May 12, 2010, 11:42:41 pm »
I'm all in to getting the right part - thing is they've only got a 2.25" for Mk II/III cars, at least that's all they list on the website.  Build my own would be fine, but I'd have to learn to weld first!!  Probably wouldn't go over so well in the landlord's place either way...
Reply #9May 13, 2010, 10:29:15 pm
wpinnix
  • 49
« Reply #9 on: May 13, 2010, 10:29:15 pm »
Just call and talk to Josh....they can custom make an exhaust to fit the exhaust to your specific application. I'm having one done now.
Reply #10May 14, 2010, 09:05:30 am
smokin_fun
  • 65
« Reply #10 on: May 14, 2010, 09:05:30 am »
I have a 2.25 tt dp going into a 2.5" modified (no res. or muffler) tt VR6 setup. It is perfect!
They are excellent to deal with and ship things quickly. IIRC it was about four days to my door in east sooke.
