as far as I know there is no difference between the 8v and 16 PP other than maybe clamp force and the pins. I was told that the mexican pp are 2 pin and others are 1 pin... I was also told the MK3 are 1 pin and the rest are 2 pin. Just make sure that you know which pin you have and you will be fine. Also, the clutch must be the small spline IIRC it is 13/16" not 7/8" as the larger was the 16v spline. You will be fine. I have a clutchnet setup just like you are asking for, but not for sale.
Um, the motor mount looks a lot like the trans mount insert. Could be wrong though. It is a trans mount.. lol (its one of the four of what I call motor mounts lol)Also, FYI, if you didn't know, you can use the water pump gasket from a 2.0L gas water pump that is metal with rubber. I use them every time instead of the paper one. Makes a better seal too.Didn't know that, thank-you very much for the insight. Will be picking one up.
enough boost is when you have 3 dimple marks in the hood from the valve cover nuts..
