Author Topic: Compound pics  (Read 142607 times)
Reply #225July 11, 2007, 07:35:07 pm
andy2
Compound pics
« Reply #225 on: July 11, 2007, 07:35:07 pm »
Well I've had both the hx30 @29psi and hy35 @20psi on as a single now and have just now built a hybrid sort of like Hilfolk'r only I used the hx30 turbine housing and it's wheel along with the hy35's centersection and compressor.No machining required direct bolt-on.This should make it spool quicker.I'll have it on soon enough for some results :wink:
Reply #226July 12, 2007, 09:06:27 am
Helliouse
  • 164
Compound pics
« Reply #226 on: July 12, 2007, 09:06:27 am »
Here is that picture I was going to do up.
Shot at 2007-07-12
My only concern with it is the expantion and contraction rates of the block and head, you could to a two ring design, but i think that it might be more suseptable to it.
I am not sure if you would need to to the recieving cut for these, if you kept them low enough only to deform the gasket to provide a better seal.
I am also thinking that Dave's, from PP, contact might be right with a fiber gasket, it would form better to the rings.
Any way, just an idea, let me know if I am way off on this.
1990 Jetta TD...Its a Project! And wait...its built in Wolfsberg! swEEt - 1.6l TD = Dead... TDI ALH in the works...
Reply #227July 13, 2007, 05:17:06 pm
andy2
Compound pics
« Reply #227 on: July 13, 2007, 05:17:06 pm »
Your idea looks a bit too bluky for the this head (IDI) its tight enough to use 1 o-ring!Also if you look at the pics of my head you would see that we had to machine around the prechambers which could not work with your idea but Your idea would work on a TDI.
Part of the issue with sealing the head to block is due to using a turbo(s)  that are not proprely sized which leads to high  turbine inlet pressure preventing the exhaust from leaving the cylinders thus increasing cylinder pressures and raising combustion temps also.
The hybrid hx30/hy35 still won't cut it with 29 psi boost/32psi drive pressure and EGT's pegged the whole time.I'll be putting an hx35 compressor onto the hx30 turbine next hoping that is will raise boost and equalize drive psi/boost pressure,Any thoughts?
Reply #228July 13, 2007, 06:47:40 pm
Compound pics
« Reply #228 on: July 13, 2007, 06:47:40 pm »
4" exhaust and dave's pulsed manifold?
Reply #229November 01, 2007, 06:12:40 pm
andy2
Compound pics
« Reply #229 on: November 01, 2007, 06:12:40 pm »
Well I'm back to 2 turbos again for the next test we are putting a heavier spring in the k24 wastegate to better control higher boost levels.The big turbo is a non wastegated H1C off an early cummins 5.9L.The head is off to get cryo treated and to modify the precups to lower the CR and flow better.14mm headstuds are going in this time to try and keep the head down and the Inj pump is off for some more tweaking also.I really hope we can get this thing to work this time around as there are some soon to be high power TDI's that I'd like to meet up with at the track next year :twisted:.
Reply #230November 01, 2007, 06:58:07 pm
  • 1156
    • Malone Tuning Ltd.
Compound pics
« Reply #230 on: November 01, 2007, 06:58:07 pm »
Keeping an eye on this one! :)
http://www.tunezilla.com
93 Eurovan AHU TDI
17 BMW 328d wagon - Sold
09 BMW 335d 3.0L
Reply #231November 01, 2007, 08:01:46 pm
SMOKEYDUB
  • 630
Compound pics
« Reply #231 on: November 01, 2007, 08:01:46 pm »
i will be at that track next year with my rabbit :twisted:
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
Reply #232November 02, 2007, 10:32:32 am
Compound pics
« Reply #232 on: November 02, 2007, 10:32:32 am »
I cant tell ya how much I would love to see you make this work.
I have a hy35 sitting around I would love to use on something..
Keep thinking I'll just put it on the wifes Durango  :twisted:
Would rather have it on my jetta though.
Reply #233November 19, 2007, 08:45:15 am
gnavs
  • 340
Compound pics
« Reply #233 on: November 19, 2007, 08:45:15 am »
crazy stuff, eagerly awaiting updates  :D
Reply #234December 29, 2007, 04:17:23 am
dillenger1
  • 777
Compound pics
« Reply #234 on: December 29, 2007, 04:17:23 am »
Is that last pick yer oil pump pulley?
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #235December 29, 2007, 11:04:04 am
andy2
Compound pics
« Reply #235 on: December 29, 2007, 11:04:04 am »
Yeah that pully was made up over 2 years ago to raise to oil pressure as adding a second turbo lowered the pressure enough.My 1.9 engine uses the shorter 1.6td timing belt now :wink:.
14mm headstuds are now ready to go.We drilled and tapped the bigger thread in the block without removing/dismantling the engine.The head has been machined to accept the studs and hardware as well.
The pre cups have now been modded to flow better and lower the CR.Glow plugs have been replaced with custom made blank off bolts to this was done to help reduce the CR a bit more and to get the tip out of there as it does nothing for performance :twisted:.
A bigger hybrid k26/24 has been made up this time.Its basically just the Audi k26 with a machined out k24 turbine housing to accept the bigger k26 wheel.The water cooled center housing was swaped out for the k24 one as I was not interested in using the water cooled section.
Some more calculating was done to help size the 2 turbo's this time around.Slowly getting that figgered out :) .
The inj pump of off getting the fueling jacked up as well.
Thats all for now.
Reply #236December 29, 2007, 02:14:46 pm
subsonic
  • 1836
Compound pics
« Reply #236 on: December 29, 2007, 02:14:46 pm »
Quote from: "andy2"
Got any more info on this?
Reply #237December 30, 2007, 02:16:10 am
zaprzal
  • 160
    • turbodiesel.pl
Compound pics
« Reply #237 on: December 30, 2007, 02:16:10 am »
you mean, stock k24 center and housing, only bigger k26 compressor and exhaust wheels?
1.6td 170hp 290nm powered by Holset - sold
golf mk2 1.9tdi PD 193hp/400nm ;)
Reply #238December 30, 2007, 10:47:11 am
andy2
Compound pics
« Reply #238 on: December 30, 2007, 10:47:11 am »
Quote from: "zaprzal"
Now I'm confused :lol: The k26 shaft dimensions are the same as the k24 so I was able to put the k26 shaft into the k24 center housing.the machine the k24 turbine housing to accept the k26 wheel.
Reply #239December 30, 2007, 10:51:47 am
andy2
Compound pics
« Reply #239 on: December 30, 2007, 10:51:47 am »
Quote from: "subsonic"
Quote from: "andy2"
The pre cups are not orignal they are heavily modified GM 6.5TD pre cups basically.I started off with GM 6.2 precups and have now modded them to the same as the 6.5TD precups.The prechambers are basically double the stock CC's now.I have high flow 6.5 TD marine nozzles on order.They should be a good match for the prechamber and flow more than other IDI nozzles i think??
