Author Topic: Who runs a turbo timer?  (Read 6289 times)
April 18, 2010, 01:10:44 am
  • 3468
    • McScrubbins Body Wash
« on: April 18, 2010, 01:10:44 am »
Should i run a turbo timer?
http://www.enjukuracing.com/turbo-timer-type0-p-8252.html?osCsid=e6ea54168959f0dda19a4aabfbde3d79
anyone run one?
i'd love to have one and modify it a bit to not only keep the engine running but to turn on a fan on my oil cooler as it cycles and get it nice and cold for when it finally turns off.
i constantly get the feeling that my turbo is cooking the oil that gets left in it when i turn the car off. sometimes im in a rush and after driving the car hard to get to wheere you wanna go you don't exactly feel like sitting there letting the car idle to try and cool the oil.
I do understand and acknowledge the fact that gas engines have much higher EGT's but would it really be a bad idea?
« Last Edit: April 18, 2010, 01:13:23 am by Smokey Eddy »
Reply #1April 18, 2010, 01:13:44 am
GTD.
  • 183
    • http://tinyurl.com/6yk84
Re: Who runs a turbo timer?
« Reply #1 on: April 18, 2010, 01:13:44 am »
Has your turbo got a watercooled core and do you  have the auxilary run on electric water pump? if so and its working you dont need a turbo timer
[Oo=w=oO]Golf GTD
VW Diesel Mehr Kraft. Weniger Verbrauch, Aus Liebe zum Automobil
Reply #2April 18, 2010, 01:14:31 am
  • 3468
« Reply #2 on: April 18, 2010, 01:14:31 am »
No.
Reply #3April 18, 2010, 06:57:18 am
« Reply #3 on: April 18, 2010, 06:57:18 am »
What about wiring up a timer that will leave the car running for a minute or so after you take the key out? That way you can lock up and leave and it will still run and cool down.
Reply #4April 18, 2010, 07:57:30 am
« Reply #4 on: April 18, 2010, 07:57:30 am »
 :D  Back to bed I go. Carry on
Reply #5April 18, 2010, 12:22:15 pm
  • 3468
« Reply #5 on: April 18, 2010, 12:22:15 pm »
thats what a turbo timer is!
Reply #6April 18, 2010, 12:23:34 pm
  • 3468
« Reply #6 on: April 18, 2010, 12:23:34 pm »
the egts being "cool" is one thing. im talking about how hot the turbo its self is. that iron takes a long time to exchange heat tto the air
Reply #7April 18, 2010, 12:26:15 pm
truckinwagen
  • 1895
« Reply #7 on: April 18, 2010, 12:26:15 pm »
when the turbo is hot enough to worry about, the EGT's will be high from the turbine housing and exhaust manifold radiating heat to the probe.
when I ran a turbo I would just take it easy for the last minute or so of driving(in my neighborhood, etc...) and just shut it down.
83 Opel Kadett Diesel
Reply #8April 18, 2010, 12:37:01 pm
  • 3468
« Reply #8 on: April 18, 2010, 12:37:01 pm »
Mmm
Also, are we missing the cool factor of a turbo timer? =P Okay i wont spend $100 on one.
I think i'd pay $40 just for the fun of wiring it up and seeing it work.
Reply #9April 18, 2010, 12:41:03 pm
truckinwagen
  • 1895
« Reply #9 on: April 18, 2010, 12:41:03 pm »
the other reason I would not run a turbo timer is that the vw cooling system sucks(fails alot), and I would hate to leave the car running only to have it act up and overheat while I am getting a donut.
I would then have the most expensive donut on the planet, and no car to drive.
I always like to be in the car to watch the gauges in case it decides to lose oil pressure, overheat, catch fire, etc...
Reply #10April 18, 2010, 12:43:39 pm
  • 3468
« Reply #10 on: April 18, 2010, 12:43:39 pm »
Mmm yes the catching fire is problematic. which reminds me ... i need to post yet another topic :P
Reply #11April 18, 2010, 06:02:21 pm
OM617
« Reply #11 on: April 18, 2010, 06:02:21 pm »
Timers are pointless on diesels. G@ssers need them because their exhaust, even at idle, is very hot.
By the time you're at your parking spot your turbo is cool, there is no need to wait longer.
Reply #12April 19, 2010, 11:49:32 am
monkey magic
  • 120
« Reply #12 on: April 19, 2010, 11:49:32 am »
Speaking of donuts,
So you dont think that heat soak from the manifold would keep the turbo hot, regardless of exhaust gas temps?
I know for a fact that my exhaust is still toasty after i have parked and got out, and would happily wager 87 english pence that the manifold and turbo are very hot indeed at this point in time. ???
mTDi syncro
Reply #13April 19, 2010, 11:53:41 am
  • 3468
« Reply #13 on: April 19, 2010, 11:53:41 am »
Speaking of donuts,
exactly my thinking.
Im sort of thinking why not cool the whole thing down to a temp you wouldn't want to normally run the car at but enough that at idle the turbo wont be spinning at any alarming rate requiring hot oil. im talking like ... down to 45C or something. And i am refering to the temp of the cast iron of the turbo.
Reply #14April 19, 2010, 12:03:59 pm
truckinwagen
  • 1895
« Reply #14 on: April 19, 2010, 12:03:59 pm »
what you might do then is run a second temp gauge and sensor to measure the temp of the cast iron if the turbo/manifold.
a cylinder head temp sender(the kind that is installed under a spark plug) bolted on with one of the turbo to manifold bolts would give you a good reading of the temp of the casting.
run an auber gauge with the alarm set to be on until the temp drops below the preset. have the alarm power both the auber gauge on, and the fuel shutoff.
then when you shut down the car will continue to run until after the temps drop, then both the motor and gauge will shut down.
-Owen
