Author Topic: Does anyone sell new 1.6TD rods? (stockers) cause I just got bad newz  (Read 3376 times)
April 09, 2010, 07:45:53 pm
dropdtop
  • 37
Went out today to measure piston protrusion for the new HG,,, got really odd readings  #1(.77mm) #2(.89mm) #3(.89mm) #4(.02mm)
So low and behold that would explain the damn cylinder I was having probs with...  I would like to install a NEW set of 4 rods but is there any online retailer that sells em at a decent price?  This isnt a racer just a factory 92 Eco 1V engine.
Thanks,
Brad
P.S.  can someone explain the piston measurments I got? they seem high as i believe the 3 notch was 61mm?  and the car had a 2 notch installed.  I zero'd the gauge to the deck and then measure the highest point of protrusion?
Reply #1April 09, 2010, 07:59:00 pm
Re: Does anyone sell new 1.6TD rods? (stockers) cause I just got bad newz
« Reply #1 on: April 09, 2010, 07:59:00 pm »
just to add some redundancy (grabbed from brick's website)
1 notch - 1.53mm thick to suit piston protrusion of .66mm to .86mm
2 notch - 1.57mm thick to suit piston protrusion of .87mm to .92mm
3 notch - 1.61mm thick to suit piston protrusion of .93mm to 1.02mm
Reply #2April 09, 2010, 08:01:14 pm
sdwarf36
  • 159
« Reply #2 on: April 09, 2010, 08:01:14 pm »
did you measure BOTH sides of the piston? IE: at 12 AND 6 oclock? Pistons do rock in the bore. I'd measure across the pin if possible-or better yet dead in the middle.
91 Jetta on WVO na / td swap in progress.
 "VW happiness is having 4 working door handles."
Reply #3April 09, 2010, 09:03:14 pm
dropdtop
  • 37
« Reply #3 on: April 09, 2010, 09:03:14 pm »
Thanks for those measurements,, thats exactly what i needed,, guess the 2 hole(notch) gasket was the right deal,,  but the #4 piston is definately bent and I'm thinking the #1 might have got a hit 2 judging by the numbers.
And yes I measured em all at dead center of the piston,,  just wish I new all this info about these engines the last time I rebuilt it 4 years ago..  starting to think that rod was bent the whole time as I always had a cylinder that didnt like to fire when cold.
Reply #4April 09, 2010, 09:11:30 pm
« Reply #4 on: April 09, 2010, 09:11:30 pm »
Yup, that cylinder would have had low compression... particularly obvious when the engine is cold.
Reply #5April 10, 2010, 08:20:34 am
dropdtop
  • 37
« Reply #5 on: April 10, 2010, 08:20:34 am »
I'm starting to assume that nobody sells replacement rods besides getting some good used ones??
seen a guy on ebay have like 20 of em (good used) but says they are 139mm long,,,   either he messed up but I swear they are 136mm correct?
and this company says they are 136mm (looks chinese made parts) but they are $450 for a set.
http://cgi.ebay.com/Conrods-VW-Rabbit-1-6L-Connecting-Rods-conrod-Pleuel_W0QQitemZ350025354522QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item517f230d1a
Reply #6April 10, 2010, 02:36:09 pm
rabbid79
  • 684
« Reply #6 on: April 10, 2010, 02:36:09 pm »
I believe there was a guy on thesamba.com that was selling a pair of new 1.6 rods.  You might want to check it out.
'15 WRX
