Author Topic: 1.6L diesel head swap ??  (Read 3756 times)
April 06, 2010, 03:26:16 pm
doonboggle
  • 179
« on: April 06, 2010, 03:26:16 pm »
Are the diesel heads for a 1.6L engine ...
one off of a non turbo engine ...
the other from a turbo engine ...
interchangeable?
doonboggle
1981 Rabbit pickup; 1.6L diesel
2006 Jetta TDI
1971 VW Karman Ghia convertible
Reply #1April 06, 2010, 03:37:19 pm
Kantdrivefast
  • 196
Re: 1.6L diesel head swap ??
« Reply #1 on: April 06, 2010, 03:37:19 pm »
interchangeable?
Some say yes, some say no...
I've got a mech N/A head on my hydro turbo block...
« Last Edit: April 06, 2010, 03:49:05 pm by Kantdrivefast »
Reply #2April 06, 2010, 03:41:14 pm
« Reply #2 on: April 06, 2010, 03:41:14 pm »
Depends if the head bolts are the same size, they started out with 11mm and partway through 81 started making 12mm.
12mm is lots better.
The other thing is some are hydro and some are mechanical.
Reply #3April 06, 2010, 03:43:33 pm
« Reply #3 on: April 06, 2010, 03:43:33 pm »
1.6L had some with 11mm headbolts if I remember and those won't work for the 12mm turbo heads. Also, if one is mechanical and the other is hydro lifters then you can't just bolt it on even if they are both 12mm heads.
BUT
From what others here have done then the quick answer is yes. If you have a head that matches specs you can run it in STOCK form with no troubles. Boosting more than stock you might want to replace the valves with stainless or the OEM turbo ones.
Reply #4April 06, 2010, 03:47:58 pm
doonboggle
  • 179
« Reply #4 on: April 06, 2010, 03:47:58 pm »
What I'm trying to accomplish is to have a spare head on hand in case the one there now develops a leak from the water inlet/outlet flange that I drilled out ... due to stripped threads by p/o ... and put in heli-?? thingies ... and apparently got off center due to a PITA when re-bolted down.
doonboggle
2006 Jetta TDI
Reply #5April 06, 2010, 03:50:48 pm
Kantdrivefast
  • 196
« Reply #5 on: April 06, 2010, 03:50:48 pm »
Only reason being is there is a coolant passage where the second, smaller oil drain is. That needs to be plugged.
Reply #6April 06, 2010, 03:54:24 pm
« Reply #6 on: April 06, 2010, 03:54:24 pm »
Yep exactly why you "just can't bolt it on" but it can be done. Same as running a MLS on Mech block.
Reply #7April 06, 2010, 03:56:00 pm
doonboggle
  • 179
« Reply #7 on: April 06, 2010, 03:56:00 pm »
Along with the 12-11 bolt issue ... right?
[/quote]Only reason being is there is a coolant passage where the second, smaller oil drain is. That needs to be plugged.[/quote]
doonboggle
2006 Jetta TDI
Reply #8April 06, 2010, 05:20:39 pm
subsonic
  • 1836
« Reply #8 on: April 06, 2010, 05:20:39 pm »
interchangeable?
As long as you have like head, example:  11mm and 11mm  / 12mm mech and 12mm mech
12mm hydro and 12mm hydro, you are good to go.  You may hear some talk about difference in the metal content between turbo and non-turbo.  That has been discussed before and is pretty much a non issue.
You may find some NA heads have 1 groove keepers, some may have 3 groove keepers.  I think most turbo heads have 3 groove, might be wrong though.
Reply #9June 30, 2010, 06:40:46 am
goon
  • 35
« Reply #9 on: June 30, 2010, 06:40:46 am »
bringing this back from the dead for a quick question... do only the 12mm heads come with hydraulic set up
Reply #10June 30, 2010, 10:22:13 am
« Reply #10 on: June 30, 2010, 10:22:13 am »
you can only get a 12mm head with hydros, yes..
